  • Chris Houston 535 posts 980 karma points MVP admin c-trib
    Jun 29, 2016 @ 08:37
    Chris Houston
    ERROR Umbraco.Core.MainDom - Error while running callback, remaining callbacks will not run.
    Hi All,
    I have spent the last 24 hours trying to debug various issues appearing in a client's UmbracoTraceLog file and now seem to be down to the last issue (there were quite a few!)
    I've not come across this issue and can't find anything using by Googling the issue, so I was hoping someone in the community might be able to help?
    The full log below is a single clean start up of the application, you can see that after the above error message, the application terminates and restarts it's self.
    This site is running Umbraco 7.4.3
    Thanks in advance for any help you can give :)
    Chris
    2016-06-29 09:22:34,774 [1] INFO  Umbraco.Core.CoreBootManager - Umbraco 7.4.3 application starting on UK867416
     2016-06-29 09:22:34,937 [1] INFO  Umbraco.Core.PluginManager - Determining hash of code files on disk
     2016-06-29 09:22:34,972 [1] INFO  Umbraco.Core.PluginManager - Hash determined (took 34ms)
     2016-06-29 09:22:35,078 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of umbraco.interfaces.IApplicationStartupHandler
     2016-06-29 09:22:35,108 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of umbraco.interfaces.IApplicationStartupHandler, found 0 (took 30ms)
     2016-06-29 09:22:35,238 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter
     2016-06-29 09:22:35,239 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter, found 0 (took 1ms)
     2016-06-29 09:22:35,240 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.PropertyEditors.IPropertyValueConverter
     2016-06-29 09:22:35,261 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.PropertyEditors.IPropertyValueConverter, found 0 (took 20ms)
     2016-06-29 09:22:35,300 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Web.Mvc.SurfaceController
     2016-06-29 09:22:35,327 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Web.Mvc.SurfaceController, found 0 (took 27ms)
     2016-06-29 09:22:35,330 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Web.WebApi.UmbracoApiController
     2016-06-29 09:22:35,350 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Web.WebApi.UmbracoApiController, found 0 (took 20ms)
     2016-06-29 09:22:35,696 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.Media.IThumbnailProvider
     2016-06-29 09:22:35,700 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.Media.IThumbnailProvider, found 0 (took 4ms)
     2016-06-29 09:22:35,702 [1] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.Media.IImageUrlProvider
     2016-06-29 09:22:35,705 [1] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.Media.IImageUrlProvider, found 0 (took 3ms)
     2016-06-29 09:22:39,186 [1] INFO  Umbraco.Core.DatabaseContext - CanConnect = True
     2016-06-29 09:22:40,448 [1] INFO  Umbraco.Core.DatabaseContext - CanConnect = True
     2016-06-29 09:22:40,979 [1] INFO  Umbraco.Core.DatabaseContext - CanConnect = True
     2016-06-29 09:22:41,047 [1] INFO  Umbraco.Web.Cache.CacheRefresherEventHandler - Initializing Umbraco internal event handlers for cache refreshing
     2016-06-29 09:22:41,057 [1] INFO  Umbraco.Web.Search.ExamineEvents - Initializing Examine and binding to business logic events
     2016-06-29 09:22:41,209 [1] INFO  Umbraco.Web.Search.ExamineEvents - Adding examine event handlers for index providers: 4
     2016-06-29 09:22:41,265 [1] INFO  Umbraco.Core.CoreBootManager - Umbraco application startup complete (took 6789ms)
     2016-06-29 09:22:50,108 [8] INFO  Umbraco.Core.Sync.ApplicationUrlHelper - ApplicationUrl: http://localhost:53956/umbraco (UmbracoModule request)
     2016-06-29 09:22:51,155 [8] INFO  umbraco.content - Load Xml from file...
     2016-06-29 09:22:51,312 [8] INFO  umbraco.content - Loaded Xml from file.
     2016-06-29 09:22:58,870 [8] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.PropertyEditors.IParameterEditor
     2016-06-29 09:22:58,874 [8] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.PropertyEditors.IParameterEditor, found 0 (took 4ms)
     2016-06-29 09:23:20,400 [9] ERROR Umbraco.Core.MainDom - Error while running callback, remaining callbacks will not run.
       at Umbraco.Web.Scheduling.BackgroundTaskRunner`1.Shutdown(Boolean force, Boolean wait)
       at umbraco.content.<>c__DisplayClass2.<.ctor>b__1()
       at Umbraco.Core.MainDom.OnSignal(String source)
     2016-06-29 09:23:20,682 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Terminating (immediate)
     2016-06-29 09:23:20,682 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Cancelling tasks
     2016-06-29 09:23:20,784 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Tasks cancelled, terminated
     2016-06-29 09:23:20,785 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Terminating (immediate)
     2016-06-29 09:23:20,785 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Cancelling tasks
     2016-06-29 09:23:20,888 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Tasks cancelled, terminated
     2016-06-29 09:23:20,888 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Terminating (immediate)
     2016-06-29 09:23:20,889 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Cancelling tasks
     2016-06-29 09:23:20,996 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Tasks cancelled, terminated
     2016-06-29 09:23:20,996 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Terminating (immediate)
     2016-06-29 09:23:20,996 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Cancelling tasks
     2016-06-29 09:23:21,097 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Tasks cancelled, terminated
     2016-06-29 09:23:21,097 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Terminating (immediate)
     2016-06-29 09:23:21,097 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Cancelling tasks
     2016-06-29 09:23:21,261 [9] INFO  Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Tasks cancelled, terminated
     2016-06-29 09:23:21,511 [17] INFO  Umbraco.Core.UmbracoApplicationBase - Application shutdown. Details: BinDirChangeOrDirectoryRename
    _shutDownMessage=Change Notification for critical directories.
    bin dir change or directory rename
    HostingEnvironment initiated shutdown
    HostingEnvironment caused shutdown
    _shutDownStack=   at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo)
       at System.Environment.get_StackTrace()
       at System.Web.Hosting.HostingEnvironment.InitiateShutdownInternal()
       at System.Web.Hosting.HostingEnvironment.InitiateShutdownWithoutDemand()
       at System.Web.HttpRuntime.ShutdownAppDomain(String stackTrace)
       at System.Web.HttpRuntime.ShutdownAppDomainWithStackTrace(ApplicationShutdownReason reason, String message, String stackTrace)
       at System.Web.HttpRuntime.ShutdownAppDomain(ApplicationShutdownReason reason, String message)
       at System.Web.HttpRuntime.OnCriticalDirectoryChange(Object sender, FileChangeEvent e)
       at System.Web.FileChangesMonitor.OnCriticaldirChange(Object sender, FileChangeEvent e)
       at System.Web.DirectoryMonitor.FireNotifications()
       at System.Web.Util.WorkItem.CallCallbackWithAssert(WorkItemCallback callback)
       at System.Web.Util.WorkItem.OnQueueUserWorkItemCompletion(Object state)
       at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
       at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
       at System.Threading.ThreadPoolWorkQueue.Dispatch()
       at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
     2016-06-29 09:23:25,986 [18] INFO  Umbraco.Core.CoreBootManager - Umbraco 7.4.3 application starting on UK867416
     2016-06-29 09:23:26,041 [18] INFO  Umbraco.Core.PluginManager - Determining hash of code files on disk
     2016-06-29 09:23:26,062 [18] INFO  Umbraco.Core.PluginManager - Hash determined (took 21ms)
     2016-06-29 09:23:26,138 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of umbraco.interfaces.IApplicationStartupHandler
     2016-06-29 09:23:26,165 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of umbraco.interfaces.IApplicationStartupHandler, found 0 (took 26ms)
     2016-06-29 09:23:26,208 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter
     2016-06-29 09:23:26,210 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.PropertyEditors.IPropertyEditorValueConverter, found 0 (took 1ms)
     2016-06-29 09:23:26,211 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.PropertyEditors.IPropertyValueConverter
     2016-06-29 09:23:26,217 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.PropertyEditors.IPropertyValueConverter, found 0 (took 6ms)
     2016-06-29 09:23:26,231 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Web.Mvc.SurfaceController
     2016-06-29 09:23:26,235 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Web.Mvc.SurfaceController, found 0 (took 4ms)
     2016-06-29 09:23:26,236 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Web.WebApi.UmbracoApiController
     2016-06-29 09:23:26,250 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Web.WebApi.UmbracoApiController, found 0 (took 14ms)
     2016-06-29 09:23:26,308 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.Media.IThumbnailProvider
     2016-06-29 09:23:26,309 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.Media.IThumbnailProvider, found 0 (took 1ms)
     2016-06-29 09:23:26,311 [18] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.Media.IImageUrlProvider
     2016-06-29 09:23:26,313 [18] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.Media.IImageUrlProvider, found 0 (took 1ms)
     2016-06-29 09:23:27,767 [18] INFO  Umbraco.Core.DatabaseContext - CanConnect = True
     2016-06-29 09:23:28,310 [18] INFO  Umbraco.Core.DatabaseContext - CanConnect = True
     2016-06-29 09:23:29,016 [18] INFO  Umbraco.Core.DatabaseContext - CanConnect = True
     2016-06-29 09:23:29,160 [18] INFO  Umbraco.Web.Cache.CacheRefresherEventHandler - Initializing Umbraco internal event handlers for cache refreshing
     2016-06-29 09:23:29,188 [18] INFO  Umbraco.Web.Search.ExamineEvents - Initializing Examine and binding to business logic events
     2016-06-29 09:23:29,506 [18] INFO  Umbraco.Web.Search.ExamineEvents - Adding examine event handlers for index providers: 4
     2016-06-29 09:23:29,552 [18] INFO  Umbraco.Core.CoreBootManager - Umbraco application startup complete (took 4081ms)
     2016-06-29 09:23:37,995 [15] INFO  Umbraco.Core.Sync.ApplicationUrlHelper - ApplicationUrl: http://localhost:53956/umbraco (UmbracoModule request)
     2016-06-29 09:23:38,271 [15] INFO  umbraco.content - Load Xml from file...
     2016-06-29 09:23:38,365 [15] INFO  umbraco.content - Loaded Xml from file.
     2016-06-29 09:23:48,746 [15] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.PropertyEditors.IParameterEditor
     2016-06-29 09:23:48,751 [15] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.PropertyEditors.IParameterEditor, found 0 (took 5ms)
     2016-06-29 09:24:08,902 [15] INFO  Umbraco.Core.PluginManager - Starting resolution types of Umbraco.Core.Persistence.Mappers.BaseMapper
     2016-06-29 09:24:08,904 [15] INFO  Umbraco.Core.PluginManager - Completed resolution of types of Umbraco.Core.Persistence.Mappers.BaseMapper, found 0 (took 1ms)
     2016-06-29 09:24:10,125 [15] INFO  Project.Web.Services.ActiveUserService - Logout - siteminderId.IsNullOrWhiteSpace
     2016-06-29 09:24:10,125 [15] INFO  Project.Web.Services.ActiveUserService - Logout - IsCookieValueNotNullAndValidGuid
     2016-06-29 09:24:10,430 [15] INFO  Project.Web.Services.ActiveUserService - Logout - gvoSMSessionIdCookie
     2016-06-29 09:24:38,791 [8] INFO  umbraco.BusinessLogic.Log - Log scrubbed.  Removed all items older than 2016-06-28 09:24:38
  • Stephen 767 posts 2273 karma points c-trib
    Jul 04, 2016 @ 09:44
    Stephen
    The "MainDom" is a mechanism that we use to identify the "main domain" in case there are several app domains running for a single app. Although rare, this can happen, eg when the app domain is restarting. Some tasks (schedule publishing, managing the xml cache...) can be executed by only one single domain at a time.
    When one app domain goes down, it needs to release the MainDom. So that the next app domain can acquire it. When releasing, we have some callbacks to run, to clean up the situation. For example, we want to make sure that all currently running tasks are stopped.
    It seems that, in your case, a callback related to a background task runner is crashing. This is not what triggers the shutdown. It usually mean that the background task runner did not respond properly to the shutdown order.
    This can happen and is hard to troubleshoot. If it happens once in a while, with no impact... it is best to simply ignore it. If it happens regularly, it probably means something's wrong.
    How often do you see this?
    Jul 04, 2016 @ 11:04
    Chris Houston
    Hi Stephen,
    Thank you for your reply, we seem to be having quite a few occurrences of the application shutting down and they all seem to occur in the logs just after the BackgroundTaskRunner tasks.
    These are the different errors (obviously I've just cut each one out of the log file)
    Application shutdown. Details: BuildManagerChange
    Application shutdown. Details: ConfigurationChange
    Chris
