  • Ron G 41 posts 137 karma points
    Jun 29, 2016 @ 20:29
    Ron G
    ERROR: Sequence contains more than one matching element
    After upgrading from 7.3.4 to Umbraco 7.3.8, I am now getting an error on particular nodes:
    Failed to retrieve data for content id 5314
    EXCEPTION DETAILS:
    System.InvalidOperationException: Sequence contains more than one matching element
    STACKTRACE:
    at System.Linq.Enumerable.SingleOrDefault[TSource](IEnumerable`1 source, Func`2 predicate)
       at Umbraco.Core.Persistence.Repositories.VersionableRepositoryBase`2.GetPropertyCollection(Sql docSql, IEnumerable`1 documentDefs)
       at Umbraco.Core.Persistence.Repositories.ContentRepository.CreateContentFromDto(DocumentDto dto, Guid versionId, Sql docSql)
       at Umbraco.Core.Persistence.Repositories.ContentRepository.PerformGet(Int32 id)
       at Umbraco.Core.Cache.DefaultRepositoryCachePolicy`2.Get(TId id, Func`2 getFromRepo)
       at Umbraco.Core.Persistence.Repositories.RepositoryBase`2.Get(TId id)
       at Umbraco.Core.Services.ContentService.GetById(Int32 id)
       at Umbraco.Web.Editors.ContentController.CheckPermissions(IDictionary`2
    Any ideas how this can be fixed?
    Jun 30, 2016 @ 04:38
    Ron G
    I've tried restoring an old version of the database, reverting back to the previous version, cleared TEMP folders and the Umbraco cache file and nothing seems to work.
    Anyone have a solution for this?
    Jul 01, 2016 @ 06:58
    Ron G
    It may be a problem with particular doc types. When I try to create a node I get the error:
    Failed to retrieve data for empty content item type Subpage
    EXCEPTION DETAILS:
    STACKTRACE:
    at USDA_ARS.Umbraco.Extensions.Utilities.UmbEventHandler.PostProcessCreated(IContentService cs, NewEventArgs`1 e)
       at Umbraco.Core.Services.ContentService.CreateContent(String name, Int32 parentId, String contentTypeAlias, Int32 userId)
       at Umbraco.Web.Editors.ContentController.GetEmpty(String contentTypeAlias, Int32 parentId)
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
       at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()
    Not sure what to look at to fix this. Any advice would be helpful.
    Jul 19, 2016 @ 23:12
    Ron G
    I figured out the problem. There was a bad custom Data Type causing the issue. When I deleted it, the problem was fixed.
  • Tom 12 posts 82 karma points
    Jul 21, 2023 @ 08:01
    Tom
    How did you delete this data type?
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Mar 07, 2019 @ 10:15
    Steve Morgan
    To drag up an old thread but to hopefully help someone else in the future.
    After turning debugging on as per https://our.umbraco.com/packages/developer-tools/usync/usync/80228-is-it-possible-to-see-more-verbose-information
    We found a document type folder had been created with the same name threw a similar error. After fixing this in the backoffice (just renamed the duplicate with an underscore) uSync ran happily.
    The duplicate folder was already there and could be due to Courier, old uSync, dodgy script ... who knows!
