Hi all, I am using Umbraco v7 Razor syntax, I try to create a 3rd level sub menu, a static example here so you can get the picture. My Umbraco code:
<ul class="menuzord-menu"> @{ var maxLevelForNav = 4; var node = Umbraco.Content(1072); var home = CurrentPage.AncestorsOrSelf(1).First(); @RenderNavForNode(home, 1) foreach (var page in home.Children.Where("Visible")) { @RenderNavForNode(page, maxLevelForNav); } } @helper RenderNavForNode(dynamic page, int maxLevel) { var current = CurrentPage.Id == page.Id ? "active" : null; var node = Umbraco.Content(1072); if (page.Children.Where("Visible").Any() && page.Level == 2 ) { @:<li><a href="@page.Url" >@page.Name</a> } else { @:<li><a href="@page.Url">@page.Name</a></li> } if (page.Children.Where("Visible").Any() && page.Level < maxLevel ) { <ul class="dropdown"> @foreach (var subPage in page.Children.Where("Visible")) { @RenderNavForNode(subPage, maxLevel) } @if (item.Children.Where("Visible").Count() > 0) { foreach (var subPage in page.Children.Where("Visible")) { @:<li><a href="@subPage.Url">@subPage.Name</a></li> } } </ul> } } </ul>
I can't make the 3rd level submenu :( can you please assist? Thank you!!
Hii LD,
here ia the code for multi level menus
@{ var site = CurrentPage.Site(); if (site != null) { <ul> <li class="@(CurrentPage.Id == site.Id ? "selected" : "")"><a href="@(site.Url)">@site.Name</a></li> @traverse(site) </ul> } } @helper traverse(dynamic parent) { <ul> @foreach (IPublishedContent node in parent.Children.Where("Visible")) { <li> <a class="@(CurrentPage.Id == node.Id ? "selected" : "")" href="@node.Url">@node.Name</a> @traverse(node) </li> } </ul> }
Hope this will help you.. Cheers Sagar..!
thanks
Use the Bootstrap Megamenu
Upload image
3rd Level submenu
Hii LD,
thanks
