  • Roberto Bianchi 137 posts 446 karma points c-trib
    Jul 11, 2016 @ 10:03
    Roberto Bianchi
    Problem with db connection after moving on production server
    Hello, I had a website on local server and on localhost that's works.
    I choose to use a db with SQL CE Express.
    When I tried to transfer the website to the production server, I received an error on connection to the database:
    Umbraco cannot start. A connection string is configured but the Umbraco cannot connect to the database.
    The web.config string of the db connection is correct:
      <connectionStrings>
        <remove name="umbracoDbDSN" />
        <add name="umbracoDbDSN" connectionString="Data Source=|DataDirectory|\Umbraco.sdf;Flush Interval=1;" providerName="System.Data.SqlServerCe.4.0" />
        <!-- Important: If you're upgrading Umbraco, do not clear the connection string / provider name during your web.config merge. -->
      </connectionStrings>
    Why I receive this problem?
    Jul 11, 2016 @ 10:15
    Roberto Bianchi
    I solved removing this string on web.config, appSettings section:
    <add key="umbracoConfigurationStatus" value="7.2.7" />
