  • Nguyen Dung Tri 106 posts 606 karma points
    Jul 25, 2016 @ 03:51
    Nguyen Dung Tri
    Is there HelloWorld plugin for Umbraco CMS?
    Hi Everyones,
    I would like to ask a tutorial to create a sample plugin for Umbraco CMS. It is just like a plugin that can show a HelloWord text on home page of Umbraco CMS.
    Sincerely, Tri
  • Dennis Adolfi 1082 posts 6450 karma points MVP 7x c-trib
    Jul 25, 2016 @ 06:34
    Dennis Adolfi
    4
    Hello Nguyen.
    To get you started:
    1. Create a folder in App_Plugins called HelloWorld.
    2. Create a html file in that folder called helloworld.html.
    3. Create a javascript file in that folder called helloworld.controller.js.
    4. Create a manifest file called package.manifest.
    Your plugin structure should look something like this:
    In your helloworld.html, add:
    <div ng-controller="HelloWorldController">
        {{message}}
    In your helloworld.controller.js, add:
    function helloWorldController($scope) {
        $scope.message = "Hello World";
    To connect the html file and the js file together, add this in your package.manifest file:
        //array of files we want to inject into the application on app_start
        javascript: [
            '~/App_Plugins/HelloWorld/helloworld.controller.js'
    Lastly, you need to update /Config/Dashboard.config. Find the StartupDashboardSection section and in that add the following:
     <tab caption="Hello World">
          <control>~/App_Plugins/HelloWorld/helloworld.html</control>
        </tab>
    The result will be this in the admin welcome page:
    Hope it helps!
    Jul 25, 2016 @ 07:49
    Dennis Adolfi
    Oh, sorrry.
    You need this line at the bottom of your helloworld.controller.js:
    angular.module("umbraco").controller("HelloWorldController", helloWorldController);
    Jul 25, 2016 @ 08:00
    Nguyen Dung Tri
    Thank for your feedback, Dennis Adolfi. Now I have a first understanding of how a plugin work on Umbraco CMS.
    Sincerely, Dung Tri
    Jul 25, 2016 @ 08:01
    Dennis Adolfi
    Awesome!
    Glad i could help! :)
    Jul 25, 2016 @ 08:33
    Nguyen Dung Tri
    Hi Dennis Adolfi,
    I'm about to pack the plugin into a zip file and try to install it via "Installed packages". But I stuck at how to add the helloworld section into "/Config/Dashboard.config"? During the installation, there must be a method to do that. Could you help me about this?
    Attachment is the sample plugin for Umbraco CMS that I have made base on your instruction.
    Sincerely,
    Dung Tri
    Jul 25, 2016 @ 09:33
    Nguyen Dung Tri
    Hi Dennis Adolfi,
    I have managed to solve the issue of adding the helloworld section into "/Config/Dashboard.config".
    Inside the package.xml, I add this section:
    <Actions>
        <Action runat="install" undo="true" alias="addDashboardSection" dashboardAlias="HelloWorld">
          <section>
            <areas>
              <area>content</area>
            </areas>
            </tab>
          </section>
        </Action>
        <Action runat="install" undo="false" alias="ClientDependencyBump"/>
      </Actions>
      <Action runat="uninstall" undo="true" alias="addDashboardSection" dashboardAlias="HelloWorld">
        <section>
          <areas>
          </areas>
          </tab>
        </section>
      </Action>
    This section means:
    • Add a tab with caption HelloWorld to Content.
    • Add control helloworld to the tab within Content page.
    Note: The same action tag with runat="uninstall" will remove HelloWorld tag from Dashboard.config file when you delete your package from Umbraco CMS.
    For more information please read these articles:
    Umbraco add dashboard with code
    Example package.xml
    Sincerely,
    Dung Tri
    Jul 25, 2016 @ 09:39
    Dennis Adolfi
    Great work!!!
