I experience some issues when publishing from one domain, with multiple languages. When logged on to .com, changes made to the .no solution, doesn't take effect, before logging in to .no/umbraco, and do a republish.
The same issue as in this post https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/60117-Publishing-with-multiple-domains-in-one-instance-logging-in-out
And here
https://our.umbraco.org/forum/using/ui-questions/46580-Publishing-content-in-Umbraco-Multi-site-setup
We have sites running on Umbraco version: 7.1.8 and 7.2.8 with this problem.
It seems like it only happens on multilingual sites. The sites are running on the same app pool.
Tried to set XmlCache properties in umbracoSettings.config, with no luck.
<?xml version="1.0" encoding="utf-8" ?> <settings> <content> <XmlCacheEnabled>True</XmlCacheEnabled> <XmlContentCheckForDiskChanges>True</XmlContentCheckForDiskChanges> <ContinouslyUpdateXmlDiskCache>True</ContinouslyUpdateXmlDiskCache>
Problem with multi lang solutions and publishing
And here
