I created a CSS in the backoffice with one "format". I associated the CSS with the Richtext Editor. I still cannot see any entries in the Format drop down. did I miss anything?
what version of umbraco are you using and what does your format look like?
v7.3 - v7.4.3 there was a bug in the editor where multiple styles didn't work (so show up in the editor) http://issues.umbraco.org/issue/U4-7160 it might be that?
also, check your cache, you can get browser or Umbraco caching issues sometimes meaning you don't see updated styles.
if you open chrome with the dev tools open you can disable the caching in your browser to test that, and if you increment the version number in /config/clientdependency.config file you will force umbraco to rebuild its internal cache of css/styles and that might kick it in.
I have it working now. I had correctly navigated to the Richtext Editor entry in the Developer section, selected my CSS, and saved the changes. My guess is that, since the Document Types already existed, Umbraco did not reflect the addition of this style sheet in the RTE's properties on those pages. After I went to the Document Types in question and selected the CSS in the properties, the styles appeared in the Formats drop down.
Formats in RTE Control
Do you have that stylesheet checked off in the settings of the RTE?
Yes, that is what I meant by "I associated the CSS with the Richtext Editor."
versionnumber in/config/clientdependency.configfile you will force umbraco to rebuild its internal cache of css/styles and that might kick it in.I have it working now. I had correctly navigated to the Richtext Editor entry in the Developer section, selected my CSS, and saved the changes. My guess is that, since the Document Types already existed, Umbraco did not reflect the addition of this style sheet in the RTE's properties on those pages. After I went to the Document Types in question and selected the CSS in the properties, the styles appeared in the Formats drop down.
