Enormous node load time in backoffice and Timeouts.
Hi Everyone.
Umbraco version 7.3.1 assembly: 1.0.5780.2824
We experience an unusual error in one of our Umbraco solutions.
It takes around 10 - 60 seconds for a node to load. And sometimes we get an error that look like this.
The weird thing about this error, is that it do not get logged, in any places. Either in db or Logs. The other weird part is that if we click another node and then go back to this one. It appears with no error.
These error & Info occur from time to time in the log files.
2016-08-03 13:45:59,811 [P13924/D5/T54] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred
System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.Data.SqlClient.SqlException (0x80131904): Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding. ---> System.ComponentModel.Win32Exception (0x80004005): The wait operation timed out
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.ExecuteReader(CommandBehavior behavior)
at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteDbDataReader(CommandBehavior behavior)
at System.Data.Common.DbCommand.System.Data.IDbCommand.ExecuteReader()
at Umbraco.Core.Persistence.Database.<Query>d__7`1.MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at Umbraco.Core.Persistence.Database.Fetch[T](String sql, Object[] args)
at Umbraco.Core.Persistence.Database.Fetch[T](Sql sql)
at Umbraco.Core.Persistence.Repositories.VersionableRepositoryBase`2.GetPropertyCollection(Sql docSql, IEnumerable`1 documentDefs)
at Umbraco.Core.Persistence.Repositories.ContentRepository.CreateContentFromDto(DocumentDto dto, Guid versionId, Sql docSql)
at Umbraco.Core.Persistence.Repositories.ContentRepository.PerformGet(Int32 id)
at Umbraco.Core.Persistence.Repositories.RepositoryBase`2.Get(TId id)
at Umbraco.Core.Services.ContentService.GetById(Int32 id)
at naestvedteater.webapplication.Tasks.UpdateEventStatus.Page_Load(Object sender, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
ClientConnectionId:9858cd85-c4f9-4a61-990e-1ae295e7f3ce
Error Number:-2,State:0,Class:11
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.tasks_updateeventstatus_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
2016-08-03 13:55:30,656 [P13924/D5/T165] INFO Umbraco.Core.Persistence.UmbracoDatabase - at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
When we wanted to make a dumb of the db. To play around with it. we found out that table cmsPreviewXml and cmsPropertyData was each over 3GB data. The db it self was at 7GB.
So we found this link and cleaned up our tables. And that reduced the load time significant..
Now we have to find out why every distinct content had over 10.000 instances with different version numbers..
Hi Everyone.
Any pointers is usefull.
Is there a content item 1731?
Yes there is.
Is it a SQL Server backend or something else? As it sounds like a SQL DB issue to me.. something locking the DB tables?
The reason it is probably working the second time is that the data will then be in the SQL Cache / memory.
Probably worth profiling the SQL db on the request and see what's happening.
I keep you posted ;)
Any social media feeds or anything automated that saves to Umbraco nodes and publishes will do this.
