My apologies if this is a FAQ post, however I am new to Umbraco and was so far not able to find an answer to my question neither on Google and nor on this forums.
We are using Umbraco deployed as a WebApp on Azure, which installs Umbraco version 7.3.4.
The designer wants to use 5 different fonts on the webpage, which are not default webfonts and thus cannot be used via a fonts.googleapis.com link.
Adding the fonts in Umbraco (for example in the scripts or stylesheets) directory seems not possible via the Umbraco-web-interface. As this interface lacks an import function for remote files into these directories.
How do I add the fonts to the Umbraco filesystem in order to use them?
In the Azure management portal on your web app there is a setting to get FTP credentials for the web app. I think it is somewhere where you can get the publishing settings
With this you can upload the fonts were you want ?
How did you get your Umbraco application on Azure ? Maybe you can make it part of this deployment process.
I was searching in the Umbraco management site to do this. Via a FTP to Azure the fonts were copied quickly into the Umbraco wwwroot.
When creating the Web app Azure gives you the option to create an empty one or a vendor specific one - Umbraco being among them. This way Azure helps you through the various wizardsto setup the SQL database , making installing a web- and database-server very easy and taking only minutes.
Adding Fonts on Azure Umbraco WebApp
Hi Serge,
Dave
Hi Dave,
Thanks for putting me into the right direction.
Best regards, Serge
Hi Serge,
Glad to hear you could solve it. Don't forget to mark the post as a solution so others can find the answer as well.
Dave
