  • Dominik Becker 1 post 71 karma points
    Aug 11, 2016 @ 07:53
    Dominik Becker
    Using Kendo Ui in custom section (Umbraco 7.4.3)
    Hi, I use Umbraco and AngularJs.
    I want to use Kendo Ui in a View of a custom section, but AngularJs is already loaded and i have no opportunity to load JQuery before AngularJs. So I get an Error, because I have to load JQuery first.
    Is there any Opportunity to solve that Problem?
  • David Peck 690 posts 1896 karma points c-trib
    Aug 11, 2016 @ 08:27
    David Peck
    Other than hacking the back office files (not advisable) you can only add your own JS via App_Plugins. This article might help.
    If Angular is loaded before this point then I suspect hacking the back office is the only option, if you really do HAVE to load JQuery first.
