  • Darren Wilson 238 posts 646 karma points
    Aug 15, 2016 @ 15:49
    Darren Wilson
    Issue Upgrading
    I'm trying to upgrade an existing site from 7.3.1 to 7.4.3. I downloaded the ZIP, copied over /umbraco, /umbraco_client and /bin. First I got an DB error that I found a solution on here to fix (https://our.umbraco.org/forum/using/migrating-from-v5-to-v4-and-beyond/75050-database-upgrade-fail-on-712-to-74-manual-upgrade). Next I got a compiling error:
    CS0012: The type 'System.Object' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'.
    Any ideas how I might be able to fix this? Luckily enough I backed up first ;-)
    Thanks Darren
  • Yakov Lebski 594 posts 2350 karma points
    Aug 16, 2016 @ 21:28
    Yakov Lebski
    Add missing assembly (System.Runtime) in web.config
    <compilation debug="true" targetFramework="4.5">
      <assemblies>
        <add assembly="System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
      </assemblies>
    </compilation>
    Aug 17, 2016 @ 09:01
    Darren Wilson
    Thanks Yakov!
