  • Saied 349 posts 674 karma points
    Aug 18, 2016 @ 13:59
    Saied
    Best way to store razor/html in properties?
    This question is sort of 2 parts:
    1. I have 3 websites, they all have the same look they just differ a bit and they have different analytics and some other things. Currently I have a template for each website, but this is cumbersome. I was thinking of putting the different parts of each website into each partials and then having a single template that they all share that usings the _Layout = "Master.cshtml" for example. Is this the correct approach or a viable one?
    2. If I have properties that require html, what is the best way to create properties for these (should I use a RichTextEditor or something else? Basically I am trying to slim down the amount of views in the project.
    Thanks, Saied
  • Dennis Adolfi 1082 posts 6450 karma points MVP 7x c-trib
    Aug 18, 2016 @ 14:51
    Dennis Adolfi
    Hi Saied.
    1. To me this sounds about right, to have all three sites sharing the same template/master, and then based on specific site settings render different partials.
    2. I personally don't like putting html code in the RTE, since it always tries to "clean-up" my code. Have you checked out the built in data type "Markdown Editor"?
