I have an image there is 1920*1440 px. I have made a 1/3 - 2/3 grid, where the picture has to be in the 1/3 grid. When I put in the picture through Umbraco, the picture is sized down to 153 * 32 px. I have a CSS class on the picture, but I tried to delete all the CSS I had, and the picture is still very small.
I am out of possibilities now. Does anybody know what that could be? I am thinking if there is a function in Umbraco somehow, where a picture is automatic resizing? I tried with different pictures, but it is the same result. I also tried without the CSS, but same result.
When I make a fullsize grid the picture is normal, and also if I set the picture in a 2/3 of the grid. But I would like the picture just to be a little bit bigger than it is now in a 1/3 grid.
Have a look in your /config/grid.editors.config.js file
When you insert the image into the 1/3 grid, what is the name of the editor that you use to insert, and is that listed in the /config/grid.editors.config.js file? and if so is there a 'config' setting for 'size' that might be restricting your width and height ?
The /views/partials/grid/editors/media.cshtml contains the code that renders the image in a grid, and this passes to url of the image via the querystring these width and height settings, that cause the image to actually be resized on the serverside.
Umbraco resize my picture
Hello
I hope somebody could have an idea?`
Best Regards
Hi MadsInova
eg
regards
marc
