Hi! I'm working with two projects parallel. On both I've installed Simple301 through nuget. On the first project it works fine and it redirects from old URLs to new URLs.
But on the second project it is not working. Things that I've compared for the projects:
All files from the package are identical.
Rows are added in the table dbo.Redirects
The only real difference I can think of is that for the project it works for I first added Simple301 as an Umbraco-package before I realized it existed as a nuget-package. Before I installed the nuget I removed the package from backoffice.
Simple301 not redirecting
https://our.umbraco.org/projects/backoffice-extensions/simple-301/
Also, both sites are running on the same server.
Help appreciated!
I solved it. Apparently "/" could not be used at the end of "Old url".
