  • Brett Davis 5 posts 25 karma points
    Aug 28, 2016 @ 20:57
    Brett Davis
    How do I switch starter kits in Umbraco 7?
    I've used the webmatrix and I've got an Umbraco 7 site setup. Out of the box, the Fanoe starter kit is installed. I would like to use a different starter kit. How do I change the starter kit from Fanoe to a different one?
  • Samira 113 posts 452 karma points
    Aug 29, 2016 @ 09:12
    Samira
    Hi Brett
    try this
    You can uninstall the starter kit and install another one. First go to the developer sections, open up the folder installed packages in there click on the starter kit you have installed, then you will see a uninstall tab, in there you can click uninstall, then you will remove the starter kit.
    After you should be able to click on the install starter kit still under developer section, in the installed package folder. Then you can choose another starter kit.
    hope this help
    Regards,
    Samira
    Aug 29, 2016 @ 18:28
    Brett Davis
    Samir,
    That helped!
    Brett
    Aug 30, 2016 @ 04:46
    Samira
    Hi Brett,
    if above solution help you to solve your problem then please make sure to mark as a solution.
    Regards,
    Samira
