Noticed an error in my logs which I can't make sense of...
2016-09-03 00:06:27,929 [P9484/D2/T21] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred
System.ArgumentNullException: Value cannot be null.
Parameter name: child
at System.Web.UI.ControlCollection.Add(Control child)
at Umbraco.Web.UmbracoComponentRenderer.RenderMacro(macro m, IDictionary`2 parameters, page umbracoPage)
at Umbraco.Web.UmbracoComponentRenderer.RenderMacro(String alias, IDictionary`2 parameters, page umbracoPage)
at Umbraco.Web.UmbracoComponentRenderer.RenderMacro(String alias, IDictionary`2 parameters)
at Umbraco.Web.PropertyEditors.ValueConverters.RteMacroRenderingValueConverter.<>c__DisplayClass7.<RenderRteMacros>b__1(String macroAlias, Dictionary`2 macroAttributes)
at Umbraco.Core.Macros.MacroTagParser.ParseMacros(String text, Action`1 textFoundCallback, Action`2 macroFoundCallback)
at Umbraco.Web.PropertyEditors.ValueConverters.RteMacroRenderingValueConverter.RenderRteMacros(String source, Boolean preview)
at Umbraco.Web.PropertyEditors.ValueConverters.RteMacroRenderingValueConverter.ConvertDataToSource(PublishedPropertyType propertyType, Object source, Boolean preview)
at Umbraco.Web.PublishedCache.XmlPublishedCache.XmlPublishedProperty.get_Value()
at Umbraco.Web.Models.DynamicPublishedContent.TryGetUserProperty(GetMemberBinder binder)
at Umbraco.Web.Models.DynamicPublishedContent.<>c__DisplayClass9.<TryGetMember>b__6(Func`2 m)
at System.Linq.Enumerable.WhereSelectListIterator`2.MoveNext()
at System.Linq.Enumerable.WhereEnumerableIterator`1.MoveNext()
at Umbraco.Web.Models.DynamicPublishedContent.TryGetMember(GetMemberBinder binder, Object& result)
at CallSite.Target(Closure , CallSite , Object )
at ASP._Page_Views_ContentPageForm_cshtml.Execute() in path\to\my\view.cshtml:line 7
Some of the references in the trace make me think it's actually related to rendering a form in an RTE, which is happening in the BreakoutBox partial. The page, and form, however render fine.
Form is in the breakout box RTE. Runs fine, despite raising the error, and is only happening in prod rather than my local development site, which makes stepping into the source locally potentially a futile exercise.
Only noticed the error after upgrading from 6.0.2 to 7.5.2, might start by creating a new form and seeing if that has the same issue...
Help with exception log
Bit that's bothering me is the view is simple:
Any insight would be great.
Is your form in the bodyText of the current page or in the BreakoutBox?
Either way, there seems to be something wrong with the macroControl being add to the containerPage: https://github.com/umbraco/Umbraco-CMS/blob/dev-v7/src/Umbraco.Web/UmbracoComponentRenderer.cs#L169
It could be any number of things in this method above it though:
This renderMacro method is huge so who knows what might be going wrong there.
Anyway, easiest way to figure out (without having to guess) is to spin up a copy of the umbraco source and set a breakpoint.
Thanks Seb
Derp. My fault - had a form macro with no form guid...
