  • Glen 36 posts 168 karma points
    Sep 13, 2016 @ 02:30
    Glen
    Novice Problem please help
    I 'am new to umbraco and forgive me if my problem is simple, I 'am just getting started to learn umbraco I did follow this tutorial https://our.umbraco.org/documentation/Tutorials/Creating-Basic-Site/ I'm using VS Ultimate 2012 and Install umbraco using nuget after that I Create a document types with some properties Homepage, ContactPage, Articles, LoginPage, RegisterPage the root is Homepage, Note I 'am just following the tutorial when I hit debug at first its fine there is no errors showing, after the debug I included some folder that have been hidden and in the second time when I hit debug It shows a bunch of errors that I do not know. enter image description here
    The error is pointing at App_Data/Models/all.generated.cs This is out of my knowledge about umbraco what did I do wrong?
  • Dennis Adolfi 1082 posts 6450 karma points MVP 6x c-trib
    Sep 13, 2016 @ 06:42
    Dennis Adolfi
    101
    Hi Glen.
    Try to Exclude this folder from your solution: /App_Data/Models/.
    Best of luck!
    Sep 13, 2016 @ 07:30
    Glen
    Hi Dennis,
    Thanks for the quick response It work.
    Sep 13, 2016 @ 08:03
    Dennis Adolfi
    Great news Glen! Im glad it worked out for you, thank you for the feedback.
    Welcome to Umbraco! :)
    Take care!
