  • Tajamal 87 posts 175 karma points
    Sep 15, 2016 @ 07:55
    Tajamal
    single domain with two installation
    We are currently setting up two installation for a single domain, if one fails the other installation will take over. So my question is how would I manage umbraco.config which will be different at some point. Have any one tried this before?
    I believe i will run into a few problems like caching, locks with files in app_data?
    Sep 15, 2016 @ 20:22
    Dennis Aaen
    Hi Tajamal,
    It sound to me that you are talking about a load balancing setup, so if one sever fails then another sever will ensure that the site is running.
    Have you tried to have a look at our documentation about how to use / setup load balancing in Umbraco
    https://our.umbraco.org/Documentation/Getting-Started/Setup/Server-Setup/Load-Balancing/
    Hope this helps,
    /Dennis
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Sep 16, 2016 @ 07:10
    Dave Woestenborghs
    Hi Tajamal,
    Like Dennis pointed out you want a load balanced setup. If you are using Umbraco version 7.3.x or higher no config will be needed.
    You will have 2 webservers running the same website pointing to the same database.
    You will need a loadbalancer to handle the load between the 2 websites.
    Dave
    Sep 16, 2016 @ 07:51
    Tajamal
    Thank you guys, I have version 7.3.x :)
    This is exactly what I want to achieve. I will walk through the documentation to see what I need to do with load balancing.
    This sounds like a setup from my system admin team.
