  • Geoff 19 posts 89 karma points
    Sep 22, 2016 @ 11:12
    Geoff
    Problem setting up Load balanced environment - "No physical template file was found for template HomePage"
    I'm attempting to create a load balanced Umbraco environment using the Azure web app. I have 2 web app instances, one master designated for authoring and the second for front end presentation. Both share the same SQL Azure database. I have created a basic test home page on the master web app comprising a corresponding document type, a template, a simple Stylesheet and a js file in Scripts/libs. My page renders fine on this instance. I have copied over the contents of the wwwroot/scripts and the wwwroot/css from the file system on the master web app to the presentation web app, but when I attempt to load the page on the latter I get the error "No physical template file was found for template HomePage". When I look in the administrator on the presentation instance I can see my test document type and the test page in the Content section as they appear on the master, but although there is a template for the test page present, it has no content in it. So can someone please tell me what might have gone wrong and how I can get the test page template to replicate to this second instance?
    Thanks, Geoff
  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Sep 22, 2016 @ 12:29
    Kevin Jump
    sounds like you also need to copy over the Views folder - if you are using MVC (which is the default) then the template will exist as a file in the Views Folder - which you will also need for any partial views or macro files you create.
    Kevin
    Sep 22, 2016 @ 13:19
    Geoff
    Hi Kevin,
    Thanks, you were absolutely correct. For some reason I'd thought that the templates were stored in the database. All working now.
    Cheers, Geoff
