  • Edwin 16 posts 96 karma points
    Sep 23, 2016 @ 19:43
    Edwin
    umbraco backoffice working but not home page
    I've followed the getting started guide and setup an umbraco project using Visual Studio 2015 and installing the Umbraco Cms nuget package. I setup a MSSQL server 2014 database on my hosting and ran the project locally from Visual Studio and completed the umbraco install using the "customize" option. I went as far as the setting up a home page document type with "allow as root" and matching template that uses a master template and I also created a home page content node.
    After that I deployed the web site to my hosting environment using the Web Deploy publishing option in Visual Studio. Now when I try to go to the home page Chrome says
    "This site can’t be reached
    The webpage at "domain.com" might be temporarily down or it may have moved permanently to a new web address. ERRCONTENTDECODING_FAILED"
    However the backoffice seems to work just fine. And I can get to the home page when I run the project locally as well.
    Also here's a stacktrace from the log. Looks like the server on my hosting environment is throwing some type of error for home page requests?
    2016-09-23 12:01:54,362 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Terminating (immediate) 2016-09-23 12:01:54,362 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Cancelling tasks 2016-09-23 12:01:54,487 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [KeepAlive] Tasks cancelled, terminated 2016-09-23 12:01:54,487 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Terminating (immediate) 2016-09-23 12:01:54,487 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Cancelling tasks 2016-09-23 12:01:54,597 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [Umbraco.Web.Scheduling.IBackgroundTask] Tasks cancelled, terminated 2016-09-23 12:01:54,597 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Terminating (immediate) 2016-09-23 12:01:54,597 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Cancelling tasks 2016-09-23 12:01:54,706 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [LogScrubber] Tasks cancelled, terminated 2016-09-23 12:01:54,706 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Terminating (immediate) 2016-09-23 12:01:54,706 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Cancelling tasks 2016-09-23 12:01:54,815 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledPublishing] Tasks cancelled, terminated 2016-09-23 12:01:54,815 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Terminating (immediate) 2016-09-23 12:01:54,815 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Cancelling tasks 2016-09-23 12:01:54,925 [P22240/D9/T41] INFO Umbraco.Web.Scheduling.BackgroundTaskRunner - [ScheduledTasks] Tasks cancelled, terminated 2016-09-23 12:01:54,925 [P22240/D9/T25] INFO Umbraco.Core.UmbracoApplicationBase - Application shutdown. Details: BinDirChangeOrDirectoryRename
    _shutDownMessage=Change Notification for critical directories. bin dir change or directory rename HostingEnvironment initiated shutdown Change Notification for critical directories. bin dir change or directory rename HostingEnvironment caused shutdown
    shutDownStack= at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.getStackTrace() at System.Web.Hosting.HostingEnvironment.InitiateShutdownInternal() at System.Web.Hosting.HostingEnvironment.InitiateShutdownWithoutDemand() at System.Web.HttpRuntime.ShutdownAppDomain(String stackTrace) at System.Web.HttpRuntime.OnCriticalDirectoryChange(Object sender, FileChangeEvent e) at System.Web.FileChangesMonitor.OnCriticaldirChange(Object sender, FileChangeEvent e) at System.Web.DirectoryMonitor.FireNotifications() at System.Web.Util.WorkItem.CallCallbackWithAssert(WorkItemCallback callback) at System.Web.Util.WorkItem.OnQueueUserWorkItemCompletion(Object state) at System.Threading.QueueUserWorkItemCallback.WaitCallbackContext(Object state) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem() at System.Threading.ThreadPoolWorkQueue.Dispatch() at System.Threading.ThreadPoolWaitCallback.PerformWaitCallback()
    Anyone know how to fix this issue? Do I need to contact my hosting provider?
    Edwin
  • Sotiris Filippidis 286 posts 1501 karma points
    Sep 24, 2016 @ 07:47
    Sotiris Filippidis
    It looks like your problem is IIS related rather than Umbraco related - from a quick search I did it looks like it has something to do with compression.
    I'm sorry that I don't elaborate further but I've got limited time at the moment. Maybe this post on Stackoverflow could prove helpful since it deals with a similar case: https://stackoverflow.com/questions/15112104/how-to-fix-err-content-decoding-failed-when-dynamic-compressing
    Sep 26, 2016 @ 01:03
    Edwin
    You are correct. I turned off HTTP compression and now I can see the home page. Thanks!
