  • Robert Stigsson 47 posts 158 karma points
    Oct 03, 2016 @ 15:05
    Robert Stigsson
    Scheduled Publishing Problems
    Hi!
    We have experienced problems with Scheduled Publishing since we launched our site a year ago, but now we finally got time to look into it.
    The problem seems to be with our database, since I can't get it to work with my local machine when I connect to the database. So, the question is: How can I debug Scheduled Publishing? Is there anyway I can hook into the Scheduled Publishing event? Otherwise, is there any other way I can debug the problem?
    If it helps, I think we started with 7.1 earlier this year, and has upgraded to 7.3 and then 7.4.3 (where we are now, and that was the version I tried with on my local machine).
    Best Regards Robert
  • Vetrivel 21 posts 130 karma points
    Dec 03, 2020 @ 10:17
    Vetrivel
    Hi Robert, Did you get any fix for this, Did you find any ways to debug the Scheduled Publishing, We are now facing this issue, the Scheduled Publishing not working as excepted.
    We are using Umbraco V 7.15.6.
    Dec 04, 2020 @ 05:37
    Vetrivel
    After a lot of debugging and search, finally works fine.
    by referring to these two below URLs we make the Scheduled Publishing working fine.
    Ref 1:https://our.umbraco.com/forum/core/general/63695-Scheduled-tasks-not-working-in-load-balanced-environment
    Ref 2:https://our.umbraco.com/forum/using-umbraco-and-getting-started/85140-scheduled-publish-and-unpublish-not-working
