  • Nadeya 4 posts 86 karma points
    Oct 12, 2016 @ 10:41
    Nadeya
    Url Picker, umb-control-group.html, umb-pane.html
    Hi all.
    The issue is about using Url Picker. It is working well at local environment but after deployment it was the problem that when editing url there is not all the form for editing is displayed. There are 2 errors in console:
    • Failed to load resource mysite.com/umbraco/views/components/html/umb-control-group.html?umb__rnd=7.5.3.16101210
    • Failed to load resource mysite.com/umbraco/views/components/html/umb-pane.html?umb__rnd=7.5.3.16101210
    What can be cause of this problem?
    Thanks, Nadya.
    Oct 12, 2016 @ 21:25
    Alex Skrypnyk
    Hi Nadya,
    How did you deploy your project?
    Are these files accessible by get from browser ?
    Alex
    Oct 13, 2016 @ 11:49
    Nadeya
    Hi Alex,
    For deployment we use MSDeploy.
    Log says that files were deployed but they are not accessible from browser.
    Nadya
    Oct 13, 2016 @ 16:04
    Alex Skrypnyk
    Hi Nadya,
    So there are no file on the server, we need to fix it.
    Is it included to the project? Sometimes not incuded files are not deployed.
    Alex
  • Ian 178 posts 752 karma points
    Oct 13, 2016 @ 16:45
    Ian
    First check as alex says that the files are on the server. If they are but not accessible one idea is to check that there are no rewrite rules in place there with the intention of protecting access to the backoffice, which could be causing problems.
    Oct 14, 2016 @ 11:54
    Nadeya
    Files are not included in the project but they are on the server.
  • Anton 28 posts 116 karma points
    Oct 17, 2016 @ 08:49
    Anton
    Chiming in
    Files are not included in project as they are automatically included in deployment package by Umbraco task. Files is present on server. Direct request with cURL returns status 200 However, all request to those files in Umbraco itself results in error 500 (server-side, related to DependencyHandler), but there is no traces of this error on server itself (no Umbraco log about error, no Application log about error)
    Oct 17, 2016 @ 09:49
    Anton
    Here complete stack trace from console with debug="true" in web.config:
    angular.min.js?cdv=1861646652:63 Error: Failed to load template: views/components/html/umb-control-group.html?umb__rnd=7.5.3.1861646652
        at Error (native)
        at http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:49:278
        at http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:100:434
        at o (http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:80:3)
        at http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:81:80
        at Object.$eval (http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:92:272)
        at Object.$digest (http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:90:142)
        at Object.$apply (http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:92:431)
        at j (http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:101:80)
        at r (http://uat/umbraco/lib/angular/1.1.5/angular.min.js?cdv=1861646652:104:449)
    Domain is whitelisted at ClientDependency.config
    Oct 17, 2016 @ 10:24
    Anton
    101
    Finally, with help of my colleagues, I was able to fix this problem. It was related to server-setup: we've missed ServerSide Include IIS web role feature. After installation of this feature error was gone
