  • Alexander 3 posts 73 karma points
    Oct 12, 2016 @ 12:48
    Alexander
    Issue with uninstalling packages after upgrade to 7.5.3
    We have got an issue with uninstalling packages after upgrade to 7.5.3. As soon as we click on any package under 'Installed packages' node, we get the following error:
    2016-10-12 14:32:38,086 [P5208/D20/T500] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object. at umbraco.cms.businesslogic.packager.data.Save(PackageInstance package, String dataSource) at umbraco.cms.businesslogic.packager.InstalledPackage.Save() at umbraco.presentation.developer.packages.installedPackage.Page_Load(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e)
    at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    at System.Web.UI.Page.HandleError(Exception e) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    at System.Web.UI.Page.ProcessRequest() at System.Web.UI.Page.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    What can we do to resolve this annoying problem?
    Thanks in advance, Alexander
  • Alex Skrypnyk 6181 posts 24242 karma points MVP 8x admin c-trib
    Oct 12, 2016 @ 13:14
    Alex Skrypnyk
    Hi Alexander,
    What package did you install ?
    Is this package compartible with your version of Umbraco?
    Alex
    Oct 12, 2016 @ 14:13
    Alexander
    Hi Alex,
    We didn't install any packages after the upgrade (from 7.4.something btw).
    Currently we have got the following packages:
    • Cultiv Search Engine Sitemap
    • Optimus.Core + Less and Sass providers
    • Robots.txt Editor
    • uBlogsy
    • UmbBackofficeMembershipProvider
    • uSync.Backoffice
    Is there a way to know what package causes the issue?
    Oct 12, 2016 @ 14:16
    Alex Skrypnyk
    And what package do you want to uninstall?
    Oct 12, 2016 @ 14:25
    Alexander
    Actually, we don't want to uninstall anything, but we also don't expect to see crashes of the system, so I prefer to solve the issue for future.
    Clicking on any of those packages brings that problem.
  • Nick Renny 31 posts 63 karma points
    Oct 21, 2016 @ 15:45
    Nick Renny
    I have the exact same problem, after upgrading from 7.4.3 to 7.5.3, on clicking any package it gives object reference not set to an instance of an object.
    [NullReferenceException: Object reference not set to an instance of an object.] umbraco.cms.businesslogic.packager.data.Save(PackageInstance package, String dataSource) +469 umbraco.cms.businesslogic.packager.InstalledPackage.Save() +52 umbraco.presentation.developer.packages.installedPackage.Page_Load(Object sender, EventArgs e) +3230 System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51 System.Web.UI.Control.OnLoad(EventArgs e) +92 umbraco.BasePages.BasePage.OnLoad(EventArgs e) +14 System.Web.UI.Control.LoadRecursive() +54 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +772
  • John Bertelsen 5 posts 75 karma points
    Nov 29, 2016 @ 14:11
    John Bertelsen
    Sort of the same problem here.
    I just only get the NullReferenceException error when i actually try to uninstall a package.
    Anyone found a solution?
    /John
