Load Balanced Environment - Urls in umbracoServer table Keep Changing
We have a load balanced multi site install that consists of 2 servers sat behind the load balancer, 1 Master and 1 Slave. This has been working well for a couple of years.
We recently upgraded to v7.5.3 and disabled the previous distributedCall setting in umbracoSettings.config
<distributedCall enable="false">
We did this as per the docs so we could use Flexible load balancing.
As per the docs:
Each server hosts copies of the load balanced website files and a file replication service is running to ensure that all files on all servers are up to date
We tick this box as well.
We force all editors on to the Master to make their updates, this appears to be working fine and both copies of the site show the same id in the LMW3SVC4ROOT-lastsynced.txt file in the ~/App_Data/Temp/DistCache folder.
Both servers are registered in the umbracoServer table, the correct one is the master and the other is the slave. However, the urls are incorrect for each server! I have changed them numerous times to be what they should be which is:
For some reason the urls get changed to other urls that are used to reference the sites hosted in the installation e.g. http://fr.example.org.uk/umbraco
The computernames remain correct and untouched.
Does this matter? What are the implications of having the wrong urls in this table? The problem I see here is that the urls that get inserted will resolve to the load balancer and could terminate on either the master or the slave.
Last night I added the preferred server address to the UmbracoApplicationUrl attribute on the <web.routing /> node in umbracoSettings.config. This has had some effect and this morning the umbracoServer table is showing both servers with a url matching what I set as the UmbracoApplicationUrl. Is that expected and is it OK they are both the same url?
distributedCallsetting inumbracoSettings.configWe did this as per the docs so we could use Flexible load balancing.
As per the docs:
Masterto make their updates, this appears to be working fine and both copies of the site show the same id in theLMW3SVC4ROOT-lastsynced.txtfile in the~/App_Data/Temp/DistCachefolder.Both servers are registered in the
umbracoServertable, the correct one is the master and the other is the slave. However, the urls are incorrect for each server! I have changed them numerous times to be what they should be which is:http://live1.example.org.uk/umbraco http://live2.example.org.uk/umbraco
Thanks, Simon
UmbracoApplicationUrlattribute on the<web.routing />node in umbracoSettings.config. This has had some effect and this morning theumbracoServertable is showing both servers with a url matching what I set as theUmbracoApplicationUrl. Is that expected and is it OK they are both the same url?is working on a reply...
