  • Bendik Engebretsen 105 posts 202 karma points
    Oct 14, 2016 @ 14:13
    Bendik Engebretsen
    tinyMCE HTML tidying
    I'm pulling my hair out trying to get the RTE in Umbraco 7 to accept HTML b tags when pasting HTML in the "Source code" window. As soon as I click OK, tinyMCE strips them away. Pasting HTML with strong tags however works fine. I've tried fiddling With the tinyMceConfig.config and the validElements tag, without any luck.
    Does anyone else have the same problem and knows how to get around it?
    Oct 15, 2016 @ 11:51
    Marc Goodson
    102
    Hi Bendik
    The world of tinymce validElements is very strange...
    By default with Umbraco for the b tag you have an entry that says:
    -strong/-b[class|style]
    the slash here means, whenever there is a b tag, replace it with a strong tag, ie b tags aren't allowed!
    so to enable b tags, you need to remove this and have a seperate entry for b tags, eg:
    -strong[class|style],-b[class|style],
    This enables both string and b tags to be entered into tinymce
    Two other gotchas though...
    with the - in front of the b tinymce will strip empty tags eg
    if you need to allow empty b tags you need to replace the - with a #
    eg
     -strong[class|style],#b[class|style],
    and final gotcha, which gets me everytime, is you need to do an app pool recycle, after each change to the configuration to see the results of the change in Umbraco!!
    hope that helps with your b tags!
    regards
    Marc
    Oct 17, 2016 @ 12:23
    Bendik Engebretsen
    Thanks Marc!
    I finally got it to work! Indeed a very strange world...
