  • Siavash Mortazavi 24 posts 145 karma points
    Oct 14, 2016 @ 14:15
    Siavash Mortazavi
    Reading From a Settings Node
    I'm using Umbraco 7.5.2. I have created a doc type for my "Global Settings" and have created a Content node on top of that document type.
    I have a static C# class, called SiteGlobalSettings that I use in my backend codes to handle global concerns.
    I want to have SiteGlobalSettings be able to read data from my "Global Settings" content node. In SiteGlobalSettings static constructor, I have this code:
    UmbracoHelper Umbraco = new UmbracoHelper();
    dynamic globalSettingsContent = Umbraco.Content(...global setting node id...);
    After running this code, globalSettingsContent will be null. I can see that UmbracoHelper has some constructor overloads. One of them recieves a UmbracoContext object, but it seems I cannot new it.
    Can someone help me achieve this please? Thank you.
    Oct 14, 2016 @ 16:38
    Alex Skrypnyk
    Hi Siavash,
    Try to do it like that:
    UmbracoHelper Umbraco = new UmbracoHelper(UmbracoContext.Current);
    It's ok, can you share code of your view?
    Also it's not perfect to use dynamics, do you know?
    Alex
    Oct 17, 2016 @ 15:59
    Siavash Mortazavi
    Hi Alex,
    That works, thank you very much! :-)
    Oct 17, 2016 @ 16:09
    Alex Skrypnyk
    Glad to help.
    Mark topic as solved and have a nice evening!
    Alex
