Is there a way to set Umbraco starting node other than default content? For example, can I set default node to "member" after backoffice user login?
Best, -Don
Hi Don,
You can configure order of sections, but I can't find config way of settings start node.
It looks like you have to change source code.
Alex
Thank you, Alex. I will check. -Don
Did you fix your issue?
Hello Alex,
Thanks for checking. No, I haven't gotten it to work. I saw the code to set allowable applications for user, but I haven't see a way to order them differently. I will continue.
Share with community what are you trying, we will find solution together.
Set Startinh Node Other Than Content
Best, -Don
Hi Don,
Alex
Hi Don,
Alex
Hello Alex,
Best, -Don
Hi Don,
Alex
