  • Jonas 123 posts 206 karma points
    Oct 19, 2016 @ 08:49
    Jonas
    Error upgrading from 7.3.8 to 7.5.3
    This works fine locally, but when moving code to production environment I get this error. All references looks ok.
    \umbraco\Views\AuthorizeUpgrade.cshtml(67): error CS1061: 'System.Web.Mvc.HtmlHelper
    Oct 19, 2016 @ 09:13
    Alex Skrypnyk
    Hi Jonas,
    Did you change this file?
    In our version of Umbraco there are no extension method AngularExternalLoginInfoValuesScript.
    Alex
  • Yakov Lebski 594 posts 2350 karma points
    Oct 19, 2016 @ 17:54
    Yakov Lebski
    2
    Simple solution is copy umbraco and umbraco_client from packages files
  • Stuart Aldridge 1 post 71 karma points
    Oct 20, 2016 @ 15:51
    Stuart Aldridge
    I have also encountered this error today whilst upgrading from 7.3.3 to 7.5.3 using Nuget, however I can't even run the project locally.
    The file AuthorizeUpgrade.cshtml has not been edited manually but I can see from version control that there have been quite a few changes made to this file - included the introduction of the below.
            document.angularReady = function (app) {     @Html.AngularExternalLoginInfoValuesScript((IEnumerable<string>)ViewBag.ExternalSignInError)
    </script>
    Any help would be appreciated on this.
    Thanks, Stuart
  • Euge 23 posts 130 karma points
    Jun 08, 2017 @ 11:58
    Euge
    I've just made a copy of the Umbraco database for a site pointed the site to the copy and I'm getting the same error as above. This only happens when I go to the back office. I'm using 7.5.3
    Oct 20, 2016 @ 16:18
  • Jesse Andrews 191 posts 716 karma points c-trib
    Feb 21, 2018 @ 01:07
    Jesse Andrews
    I'm running into this issue as well after upgrading from 7.4.3 to 7.5.14 with nuget. It works fine in my local environment, but it fails once it's deployed to azure. I've confirmed that the solution in the other thread isn't the answer, as none of my references point anywhere they shouldn't be.
    I also tried manually copying over the dlls, but sadly that didn't help. The problem isn't the dll itself, as I confirmed that the extension is inside umbraco.dll.
    Lastly, I tried bypassing the issue by running the upgrade in my local environment, which upgraded the database without issue. This script is used throughout umbraco though, so that didn't avoid the problem.
  • John Ligtenberg 53 posts 214 karma points
    May 15, 2018 @ 15:39
    John Ligtenberg
    I've also run into this issue when deploying a site to Azure after an Umbraco upgrade from 7.3.5 to 7.10.4
    The site was working fine locally.
    By copying the umbraco and umbraco_client folders into the site manually, from my local site to Azure, I was able to do the database upgrade. After a subsequent TeamCity deployment the problem returned. It looks like I may have to add the umbraco and umbraco_client folders to GIT.
    I hope someone has a better solution. Is this a bug?
