  • truels vallø bisgaard 8 posts 77 karma points
    Nov 03, 2016 @ 16:15
    Help. Can't change a thing
    Can anybody help? If a make changes and push the publish button I get a message (see below), I don't know what means??? "Server Error in '/' Application. A potentially dangerous Request.Form value was detected from the client (ctl00$body$bodyText="
    Jeg arbejder prim..."). Description: ASP.NET has detected data in the request that is potentially dangerous because it might include HTML markup or script. The data might represent an attempt to compromise the security of your application, such as a cross-site scripting attack. If this type of input is appropriate in your application, you can include code in a web page to explicitly allow it. For more information, see http://go.microsoft.com/fwlink/?LinkID=212874.
    Exception Details: System.Web.HttpRequestValidationException: A potentially dangerous Request.Form value was detected from the client (ctl00$body$bodyText="
    Source Error:
    The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
    1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
      <%@ Page Language="C#" Debug="true" %>
    or:
    2) Add the following section to the configuration file of your application:
    Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
    Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
    Stack Trace:
    [HttpRequestValidationException (0x80004005): A potentially dangerous Request.Form value was detected from the client (ctl00$body$bodyText="
    Jeg arbejder prim...").] System.Web.HttpRequest.ValidateString(String value, String collectionKey, RequestValidationSource requestCollection) +9800232 System.Web.HttpRequest.ValidateHttpValueCollection(HttpValueCollection collection, RequestValidationSource requestCollection) +194 System.Web.HttpReque"
    Nov 03, 2016 @ 20:09
    Hi Truels and welcome to our :)
    Sounds like you're trying to add HTML content to a form field were it's not allowed. Do you know what version of Umbraco you're using? And the content you're trying to save...is it something that you have copied from word and then pasted directly into Umbraco? If so then try pasting it into notepad first and then copy and paste the content from notepad into Umbraco and see if you're then allowed to save the content.
    Hope this helps.
    Nov 04, 2016 @ 06:50
    Hi Jan, and thanx for trying to help. I'm using umbraco v 4.5.2 - "to a form field"??? I don't understand this - I get the error message no matter what I try to change and save, even if I just remove a ! or . Maybe an update of Umbraco, is that possible, and if so, how? Regards
    Nov 04, 2016 @ 14:55
    Hi Truels
    Ok, so are you a developer or a content editor? Can you paste a screendump of what the page you're trying to edit looks like before you hit the publish button?
    Nov 04, 2016 @ 17:22
    I'm a content editor. It's with every page, and with every change I try, even if I just try to delete one letter... What you see in this screen pic is found on www.happyhorses.dk enter image description here
    Thanx for trying :)
    Nov 04, 2016 @ 17:27
    And maybe it's important that I have the same problem on every page if I hit the publish button, even without making any change - I get the error message....
    Nov 05, 2016 @ 12:03
    Hi Truels
    Ok I see - Then all the tech stuff we mentioned before does not make any kind of sense to you :)
    I'm afraid it's a bit hard for us to help you even further since it's an old version of Umbraco that you're using and we don't have a chance to figure out what is going on and why it's failing all of the sudden.
    I suppose you have had some help from a freelancer or a company to develop the solution for you back in the days - Perhaps you can get in touch with them so they can investigate things further and help you out?
    Nov 06, 2016 @ 19:06
    hi, I'm trying desperate to get in touch with them.
    If i fail, I'll try to reach out to find somebody else with the talents needed...
    Thanx for your effort Truels
    Nov 06, 2016 @ 20:31
    Hi Truels
    You're welcome - I hope you succeed so you can edit the content of your website again.
    If you don't succeed getting in touch with those people who originally made your site then you can try getting in touch with the certified developers / companies listed on these pages https://umbraco.com/certified-partners/find-a-certified-developer/ - Perhaps it's a good idea to have a look at the version 4 list in your case.
  • Manish 373 posts 932 karma points
    Nov 04, 2016 @ 08:27
    Manish
    Check that you placed your description at right place not in validation box.
    Nov 04, 2016 @ 09:50
    I don't understand, my description?
    Nov 04, 2016 @ 10:41
    Manish
    Description of property you added while creating it
    Nov 04, 2016 @ 11:33
    sorry but u might as well be talking chinese - I've got no clue to what you mean.??? I've been changing things on my website for 8 years now, and all of a sudden I cant???
    Nov 04, 2016 @ 13:02
    Manish
    I am taking about this validation and description box it sometime gives error when you place description in validation box. hope you are able to understand
    Nov 04, 2016 @ 17:26
    I truly appreciate your effort, but the page shown I've never seen nor would know where to find. I'm the content editor I should mention... I have the same problem on every page if I hit the publish button, even without making any change - I get the error message....
  • Phillipe Nelson 4 posts 75 karma points
    Nov 09, 2016 @ 17:46
    Phillipe Nelson
    I am experiencing the very same issue. This could be caused by my version, 4.0.4.2 running on IIS 8.5. Site loads fine, but cant save at all.
