    Nov 07, 2016 @ 12:31
    Lee Kelleher
    Grid Settings: CheckboxList PreValueEditor?
    Has anyone made, or know how to make a CheckboxList PreValueEditor?
    I'd like to use one for the Grid settings, (I've checked the docs, but there isn't one).
    Another thread mentions the need for one, but nothing seems to have come of it.
    If anyone has already built a checkboxlist prevalue editor (as opposed to the property-editor), and is willing to share it... that would be hugely appreciated.
    Thank you,
    - Lee
  • Rune Grønkjær 1372 posts 3103 karma points MVP
    Nov 07, 2016 @ 15:15
    Rune Grønkjær
    102
    I have made one that works like a charm. Heres the code.
    Javascript: http://pastebin.com/uCPSXwnB
    Html: http://pastebin.com/sMCeycvg
    Settings: http://pastebin.com/vptcQb10
    EDIT: Stylesheet: http://pastebin.com/FNT9PxXB
    EDIT 2: I changed the settings file. Took the wrong one. They look so much alike.
    Nov 07, 2016 @ 15:21
    Rune Grønkjær
    It looks like this in action enter image description here
    Nov 07, 2016 @ 15:25
    Rune Grønkjær
    Heres another settings for it, where it adds one or more classes depending on the checked values: http://pastebin.com/TNuhBcP7
    Nov 07, 2016 @ 15:38
    Lee Kelleher
    Thanks Rune, that is very very much appreciated! #h5yr
    - Lee
  • Martin 278 posts 662 karma points
    Nov 18, 2016 @ 08:53
    Martin
    Hi Rune,
    This looks great. As one of those designer types, where do I drop those files within Umbraco?
    Martin
    Nov 18, 2016 @ 09:04
    Rune Grønkjær
    2
    The files (html, javascript and stylesheet) should be placed in a folder in your App_Plugins folder. It's much like creating a new editor like here: https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/Grid-Layout/build-your-own-editor
    Make sure you add a package.manifest file, as the guide says.
    After that you add the settings part of my example to the Grid layout data type you are using on the page.
    More specific you can both use it on the "Settings" and/or "Styles" part of the Grid layout.
    Read more about that in general here: https://our.umbraco.org/documentation/getting-started/backoffice/property-editors/built-in-property-editors/Grid-Layout/Settings-and-styles
  • Nigel Wilson 945 posts 2077 karma points
    Nov 24, 2018 @ 18:54
    Nigel Wilson
    Hi Rune
    It's 2 years after you published this, but I have just found it today and it has solved a curly issue I have been mulling over for a rebuild of my partners site.
    I was wanting a way to be able to set multiple css classes on a row, so this option is a perfect idea / solution to setting classes.
    Thanks heaps for sharing
    Nigel
    Nov 26, 2018 @ 07:14
    Rune Grønkjær
    Cheers :)
    Nov 18, 2016 @ 13:39
    Martin
    Hi Rune, Brilliant. Got it working. Thanks.
    Martin.
    Nov 18, 2016 @ 14:04
    Rune Grønkjær
    That's fantastic. It's a pretty nifty little editor if I should say so myself.
