  • Aron 12 posts 43 karma points
    Nov 08, 2016 @ 13:33
    Aron
    Add Surface Controller to existing site
    I've been asked to work on an existing v7 site that is very basic and I need to add some surface controllers/apis.
    Is it better to create a local Umbraco site, create the controllers etc. and copy the dll's over to the existing site or just create a local class library and add the umbraco dll's?
    I don't want to just add classes to the app_code folder as there is a lot more development coming.
    Aron
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Nov 08, 2016 @ 17:06
    Alex Skrypnyk
    101
    Hi Aron,
    If you planned to do a lot of c# logic, of course it will be better to have local Umbraco site and possibility to compile all code to dll and deploy.
    Alex
    Nov 09, 2016 @ 10:36
    Aron
    Thanks for this, i'll give that a go.
    Nov 09, 2016 @ 13:10
    Aron
    Thanks again, works perfectly!
