I'm creating a site in Umbraco, using its grid editor but for some reason, the content isn't full width of the page due to an awkward 'container' class, I've tried editing the content generator in the grid's configuration files but it doesn't seem to help as I'm left with an extra floating margin either to the left or right of the page.
The code snippet above is the HTML being generated by the default grid config settings.
The grid is set up with a full-width page & full-width column.
Here are some screenshots:
Also please ignore content text as the project is still under development as you can see, so please ignore any grammar & bad word choice, it is currently just quick content filler which is also going to be used as notes for when I'm populating the content, Thanks!
You need to customize the view used by the grid system. These views can be found in \Views\Partials\Grid\ By default the grid system uses the bootstrap3 one, but you can tell the grid system to use bootstrap2 or any other view.
@Html.GetGridHtml(Model.Content, "NAME_OF_VIEW")
Here i have removed the most obvious things i can see that might help you design back on track(i have not tested it).
@inherits UmbracoViewPage<dynamic>
@using Umbraco.Web.Templates
@using Newtonsoft.Json.Linq
Razor helpers located at the bottom of this file
@if (Model != null && Model.sections != null)
var oneColumn = ((System.Collections.ICollection)Model.sections).Count == 1;
@if (oneColumn)
foreach (var section in Model.sections) {
@foreach (var row in section.rows) {
@renderRow(row, true);
}else {
<div class="container">
<div class="row">
@foreach (var s in Model.sections) {
<div class="col-md-@s.grid">
@foreach (var row in s.rows) {
@renderRow(row, false);
@helper renderRow(dynamic row, bool singleColumn){
<div @RenderElementAttributes(row)>
@Umbraco.If(singleColumn, "<div class=\"container\">")
<div class="row">
@foreach ( var area in row.areas ) {
<div class="col-md-@area.grid">
<div @RenderElementAttributes(area)>
@foreach (var control in area.controls) {
if (control !=null && control.editor != null && control.editor.view != null ) {
<text>@Html.Partial("grid/editors/base", (object)control)</text>
</div>}
@Umbraco.If(singleColumn, "</div>")
@functions {
public static MvcHtmlString RenderElementAttributes(dynamic contentItem)
var attrs = new List<string>();
JObject cfg = contentItem.config;
if(cfg != null)
foreach (JProperty property in cfg.Properties()) {
attrs.Add(property.Name + "='" + property.Value.ToString() + "'");
JObject style = contentItem.styles;
if (style != null) {
var cssVals = new List<string>();
foreach (JProperty property in style.Properties())
cssVals.Add(property.Name + ":" + property.Value.ToString() + ";");
if (cssVals.Any())
attrs.Add("style='" + string.Join(" ", cssVals) + "'");
return new MvcHtmlString(string.Join(" ", attrs));
Thanks for the response bud, I tried what you sent and even tried playing around with again myself but it still doesn't seem to be working which is incredibly annoying considering Umbraco & Bootstrap are supposed to be official and reliable sources, here is the result from what you said bud:
It's hard to tell but potentially this is a styling issue rather than grid specific.
In bootstrap .container restricts the width of the div so it's never wider than a maximum number of pixels.
.container-fluid removes the restriction and makes the div 100%.
However I think in your original post, the problem looks like that background color is being applied within or on the .container level, where is should be applied sooner, perhaps on the .row or anything above it.
I'm not sure what's happening in your second post - but it also looks non-grid related.
If the site is available publicly - that might help, but I'm assuming it's not.
Hi Harry,
I had the same issue when i tried to implement Foundation in place of Bootstrap.
I'll run through what i did to get a full width row.
This is your code from above with notes on where you can edit from the umbraco dashboard.
<div class="umb-grid">
<div class="grid-section">
<div> <!-- ROW SETTINGS ARE APPLIED HERE -->
<div class="row"> <!-- YOU CANT EDIT THIS IN DASHBAORD -->
<div class="container"> <!-- YOU WANT YOUR FLUID CLASS HERE -->
<div class="col-md-12 column">
<div> <!-- CELL SETTINGS ARE APPLIED HERE -->
Content Code...
You have two options.
You can either amend your css to say something like the following and then apply the class container-fluid in the row class field
.container-fluid .container {
/* your styles to make the child */
Or you could put in a if else statement in your Bootstrap partial view.
What that will do is check the name of the row type and output a different html structure with the fluid class applied.
if (row.name == "full-width") {
@Umbraco.If(singleColumn, "<div class='container-fluid'>") @*YOU MAY NEED TO REMOVE THIS AND JUST PUT IN PLACE A DIV WITH CLASS *@
<div class="row clearfix">
<div class="col-md-@area.grid column">
</div>}
} else {
@Umbraco.If(singleColumn, "<div class='container'>") @*YOU MAY NEED TO REMOVE THIS *@
</div>}
@Umbraco.If(singleColumn, "</div>") @*YOU MAY NEED TO REMOVE THIS *@
Umbraco 7.5.4 - Grid layout, not full width
@Html.GetGridHtml(Model.Content, "NAME_OF_VIEW")Here i have removed the most obvious things i can see that might help you design back on track(i have not tested it).
Hi Harry, I had the same issue when i tried to implement Foundation in place of Bootstrap.
.container-fluid .container { /* your styles to make the child */ }
Or you could put in a if else statement in your Bootstrap partial view. What that will do is check the name of the row type and output a different html structure with the fluid class applied.
Thanks Martin, I used what you sent and found a solution for my problem, much appreciated!
Hi Harry,
I have the same issue which you had faces, could you please send me the file where I need to update for full width grid layout.
