  • J 447 posts 864 karma points
    Nov 11, 2016 @ 09:22
    J
    How to implement a fix?
    I have a bug with Umbraco version 7.1. I have found a thread where there is a proposed fix found on github. The fix is to change some code in the util.service.js file (which is the path listed on github). When i search for this file in Umbraco it doesnt exist?
    What steps could i take to add these few lines of code without having to upgrade the entire site? Or is the only option to upgrade the entire site?
  • Dennis Adolfi 1082 posts 6450 karma points MVP 7x c-trib
    Nov 16, 2016 @ 12:19
    Dennis Adolfi
    Hi J.
    Im not sure about this file, I can only confirm that it does´nt exist in my current solutions.
    However, upgrading is always the best option. Even if you find this file and make your code change, you´ll always have to do your changes in future upgrades since these upgrades will override your changes.
    Also, since 7.1 to 7.5.4 there are 1308 issues fixed, 48 breaking changes and 115 new features, so upgrading would be in its place. https://our.umbraco.org/contribute/releases/compare
