  • Paul Griffiths 370 posts 1021 karma points
    Nov 13, 2016 @ 15:25
    Paul Griffiths
    Model object is null question
    Hi all,
    Can some please help explain something? I’m messing around with surface controllers and i'm clearing missing something.
    I have the following Homepage razor view which has a bunch of partial defined and one html.action call.
    The Html.Action calls the following custom controller which I have defined
    At this point all the controller does is make a call to the following partial
    If I call the partial directly from the home page then the Model.Content is available. However, if i call it from the controller i get the Model is null.
    What do i need to do?
    Paul
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Nov 14, 2016 @ 07:41
    Dave Woestenborghs
    Hi Paul,
    I think the problem is that you are not passing your model to your view in your action.
    You can do this in our action :
    public ActionResult Index()
        var siteRoot = this.Umbraco.AssignedContentItem.AncestorOrSelf("homePage");
        var testimonialPage = siteRoot.Descendant("testimonialPage");
        return PartialView("Homepage/TestimonialsSection", testimonialPage)
    And then your first line in your view should be :
    @inherits UmbracoViewPage<IPublishedContent>
    Now your model in your view is the content item of the testimonialpage.
    Dave
    PS : I'm writing this from the train without testing, so there can be some syntax errors
    Dave
    Nov 15, 2016 @ 13:33
    Paul Griffiths
    Hi Dave,
    Thanks very much for responding. It makes sense what you are saying.
    Ill have have a play around and see if i can get it working :)
    Will let you know
    Paul
