  • Mahgo 32 posts 152 karma points
    Nov 15, 2016 @ 10:28
    Mahgo
    Health Check - Data Integrity issues
    I'm using the Health Check developer tool in the backend, and under XML Data Integrity, Content (Total XML: 113, Total published: 116, Total invalid 0) fails. When I click the Fix button, the following error is displayed:
    "Violation of PRIMARY KEY constraint 'PK_cmsContentXml'. Cannot insert duplicate key in object 'dbo.cmsContentXml'. The statement has been terminated."
    Stacktrace:
       at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean asyncWrite)
       at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
       at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteNonQuery() in c:\Code\github\SamSaffron\MiniProfiler\StackExchange.Profiling\Data\ProfiledDbCommand.cs:line 279
       at Umbraco.Core.Persistence.PetaPocoExtensions.BulkInsertRecords[T](Database db, IEnumerable`1 collection, Transaction tr, Boolean commitTrans)
       at Umbraco.Core.Persistence.Repositories.ContentRepository.RebuildXmlStructuresProcessQuery(Func`2 serializer, IQuery`1 query, Transaction tr, Int32 pageSize)
       at Umbraco.Core.Persistence.Repositories.ContentRepository.RebuildXmlStructures(Func`2 serializer, Int32 groupSize, IEnumerable`1 contentTypeIds)
       at Umbraco.Core.Services.ContentService.RebuildXmlStructures(Int32[] contentTypeIds)
       at Umbraco.Web.HealthCheck.Checks.DataIntegrity.XmlDataIntegrityHealthCheck.ExecuteAction(HealthCheckAction action)
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()
    Nov 16, 2016 @ 10:52
    Mahgo
    Somehow I managed to get multiple of the same node with the same ID in the cmsDocument table, I cleared all but one of them and that seemed to fix the issue.
