  • Rahulk 24 posts 54 karma points
    Nov 15, 2016 @ 14:36
    Rahulk
    How to get value from umbraco7 using C# code
    I have created a controller class and model class. Within in the model class I have written below method to get values from umbraco.
    public void GettingValueFromUmbraco(IPublishedContent content)
       Name = content.GetProperty("EmpName").Value.ToString();
       Email = content.GetProperty("email").Value.ToString();
       Mobile = content.GetProperty("mobile").Value.ToString();
    And I have called this method in Controller class.
    public ActionResult Home()
       UmbracoTest umbracoTest = new UmbracoTest();
       umbracoTest.GettingValueFromUmbraco();
       return View();
    From controller we want to pass parameter value. Anybody please help me to pass the right value to the function.
  • Alex Skrypnyk 6182 posts 24283 karma points MVP 8x admin c-trib
    Nov 15, 2016 @ 14:44
    Alex Skrypnyk
    Hi Rahulk,
    Welcome to our community!!!!
    Can you explane why do you need to get data in controller and push it to view?
    With Umbraco you can access Umbraco related data directly in view, especially if it's current page data.
    Did you look at documentation?
    https://github.com/umbraco/UmbracoDocs/tree/master/Tutorials/Creating-Basic-Site
    https://our.umbraco.org/documentation/
    And of course ask, ask and ask. We are the friendliest community!
    Alex
    Nov 15, 2016 @ 14:53
    Rahulk
    Hi Alex,
    Thank you for your quick replay.
    I am try to learn how I can get values from umbraco it into Model class. Just for learning umbraco things and C#
    Please help me to pass the right parameter for this context.
    Thanks Rahul
    Nov 15, 2016 @ 14:59
    Alex Skrypnyk
    Hi Rahul,
    Umbraco makes strongly typed models for you, just look at https://github.com/zpqrtbnk/Zbu.ModelsBuilder/wiki/Zbu.ModelsBuilder
    Alex
    Nov 15, 2016 @ 15:11
    Alex Skrypnyk
    You don't need to write such code at all:
    You already have strongly typed model of page, just render it in Razor:
    Model.Name
    Alex
    Nov 15, 2016 @ 15:42
    Rahulk
    You are right. In razor I can render like that. But how I can access it in C# for doing some business logic in model class.
    Thanks Rahul
    Nov 15, 2016 @ 16:10
    Alex Skrypnyk
    Hi Rahul,
    What exactly logic do you want to do?
    Some read or write operations?
    Alex
  • Charlie Haley 7 posts 119 karma points
    Nov 15, 2016 @ 20:23
    Charlie Haley
    Hi Rahul,
    I think you might be looking at RenderModel
    https://our.umbraco.org/documentation/reference/routing/custom-controllers
    If you make your controller have the base class of RenderMvcController and pass RenderModel into your method you'll be able to access IPublishedContent from there.
    public ActionResult Index(RenderModel umbracoModel)
            var model = umbracoModel.Content.GetProperty("email");
    Umbraco works on a naming convention basis so make sure that your Document Type has the same name as your controller.
    Hope this helps!
    Nov 16, 2016 @ 15:53
    Rahulk
    Hi Charlie,
    Thank you very much.
    Exactly am looking this one. As per your suggestion I have amened my code. Please help me to know is this the right way to implemet?
    public class HomeController : Umbraco.Web.Mvc.RenderMvcController
            public ActionResult Home(RenderModel renderModel)
                umbracoTest.GettingValueFromUmbraco(renderModel);
                return View();
    namespace UmbracoStudy.Models
        public class UmbracoTest
            public string Name { get; set; }
            public string Email { get; set; }
            public string Mobile { get; set; }
            public void GettingValueFromUmbraco(RenderModel content)
                Name = content.Content.GetProperty("EmpName").Value.ToString();
                Email = content.Content.GetProperty("email").Value.ToString();
                Mobile = content.Content.GetProperty("mobile").Value.ToString();
    Thanks Rahul
    Nov 16, 2016 @ 16:40
    Charlie Haley
    Hi Rahul,
    That looks like it would work to me! You're most likely not going to need to pass the entire RenderModel through, so just do renderModel.Content like below.
            umbracoTest.GettingValueFromUmbraco(renderModel.Content);
            return View();
    Charlie
    Nov 16, 2016 @ 16:45
    Alex Skrypnyk
    Hi Charlie and Rahul,
    Also you can use constructor:
            UmbracoTest umbracoTest = new UmbracoTest(renderModel.Content);
            return View("/views/umbracoTest.cshtml", umbracoTest);
            public UmbracoTest(IPublishedContent content)
    Can you show code of your view? Because I don't see why we need controller now.
    Alex
    Nov 18, 2016 @ 05:04
    Rahulk
    Thank you Charlie.
    Thanks & Regards Rahul
    Nov 18, 2016 @ 05:05
    Rahulk
    Hi Alex,
    As of now I didn't write the code for view. Definitely will share you once it is done or start the code.
    Nov 18, 2016 @ 10:56
    Alex Skrypnyk
    Glad to hear, wait for your reply.
    Nov 18, 2016 @ 13:10
    Rahulk
    Hi Alex, Charlie
    Below I have copied the code written in Controller, Model and View.
    Controller:
                var testModel=umbracoTest.GettingValueFromUmbraco(renderModel.Content);
                return View("/Views/Home/Index.cshtml",testModel);
    Model:
    public UmbracoTest GettingValueFromUmbraco(IPublishedContent content)
                UmbracoTest umb = new UmbracoTest
                    Name = content.GetProperty("EmpName").Value.ToString(),
                    Email = content.GetProperty("email").Value.ToString(),
                return umb;
    View:
    @model UmbracoStudy.Models.UmbracoTest
        <div class="row">
            <p>Employee Name: @Model.Name</p>
            <p>Employee Email: @Model.Email</p>
            <p>Employee Mobile: @Model.Mobile</p>
