  • andrew darby 11 posts 122 karma points
    Nov 18, 2016 @ 11:25
    andrew darby
    Changes to Datatype nuPickers Properties are not permanent
    I am using Umbraco 7.4.3 I have made changes to two different nuPickers property editors used in 2 different document types. The changes take effect and when I edit content the modified property editor works as expected. Then the following day my change to property editor is gone, and it has reverted to previous settings.
    The 2 most recent changes that had this problem were:
    1. edit nuPickers: Lucene PrefetchList Picker and set "Allow sorting" to be checked I submit the change to Editor Settings, and Property Settings and get the "document type saved" confirmation after saving the doc type
    2. edit a different nuPickers: Lucene PrefetchList Picker "Min items" value was set to 1, so that this field was required, and document could not be saved without selecting at least 1 item in nuPicker
    Change "Min items" to 0, so field is not required. Again I submit Editor Settings, and Property Settings, and save Document type.
    I did previously create a package that included this Doc type to migrate changes from DEV environment to Production, but I am making above changes direct on Production.
    any help or pointers appreciated.
