hi we are using umbraco 7 and we have a banner that rotates companys on and we want to add an external link so that when people click on the banner it takes them to that website. Thanks
Is this a website someone has built for you / your company?
The first thing to check is whether you have access to make the change required - you'll need to update the the document type and the template (it's basically HTML) but it might be easier to get someone (there are lots of freelancers out there *) to do it for you if you don't feel comfortable.
If you want to learn how to do it yourself I'd recommend stepping through the "How to Create a Basic Site" tutorial in a fresh, local copy of Umbraco - this will give you the skills you need to make these kinds of easy updates. **
banner click through to website
Hi Andrew,
Steve
'* Disclaimer - I'm a freelancer :)
** I wrote this so I'm biased here too :)
