I have installed a package - Koiak document centre - but what to do next?
How do I use the package, stick it on my website, configure it?
I have looked on the package documentation and Our Umbraco but can see no clues how to implement an installed package.
Using Umbraco 7.5.3
Thank you
I had not heard of this package, https://our.umbraco.org/projects/starter-kits/document-centre/, but a quick look at the code confirms it won't work with Umbraco 7 as its not compatible with Angular.
Prior to Umbraco 7, we used to use Web Controls to create packages, now you have to use Angular.
If you next question is, How do I convert an Umbraco 4/6 package to Umbraco 7 ? the answer is, with a complete new re-write. Sorry.
Cheers
Thank you Jonathan.
Is their a protocol for implementing installed packages? Do you have to create a document type or edit a template? I just don't know where to start.
Thanks.
Hi Robert,
Welcome to a new world of pain. Feel free to start here
https://our.umbraco.org/forum/umbraco-7/developing-umbraco-7-packages/70492-step-by-step-guide-of-the-creation-of-a-package-for-umbraco-v7x
I have installed package, what next?
Using Umbraco 7.5.3
Thank you
Cheers
Thank you Jonathan.
Thanks.
Hi Robert,
Cheers
