  • André van der Plas 18 posts 108 karma points
    Dec 02, 2016 @ 14:40
    André van der Plas
    Link to Document issues
    Question from a newbie :-)
    I've created a list of Content which respresent my mainmenu. So far so good. Now I'm trying to create a "subitem" under one of the main items. That's also no problem but when I look at the Link to Document is see e.g. the following:
    Link to document: /organisation/
    Instead of /about-us/organisation/
    Why is de "/about-us" missing?
    Can someone set me on the right track?
    Thanks in advance.
    André van der Plas
  • Steve Morgan 1350 posts 4460 karma points c-trib
    Dec 02, 2016 @ 14:55
    Steve Morgan
    Can you post a screenshot of your content structure. Is everything under a "home" node.
    E.g.
    • Home
      • About Us
      • Contact Us
      • History
    or have you put About-us at the root level the same as home?
    Dec 02, 2016 @ 15:01
    André van der Plas
    Hi Steve,
    Hereby a screenshot. Names are in Dutch but the example I described is
    "Over ons" -> "Organisatie"
    Dec 02, 2016 @ 15:42
    Steve Morgan
    You can do this - there is a config setting somewhere to allow this but I've found it causes issues later on. I'd recommend you move it to have all pages under the homepage.
    Usually you create a special doc type of Homepage and allow this at root and nothing else (except maybe a site settings node - or content block container).
    I know some people see the home page as at the same level as their root page but consider the URL structure.
    www.mydomain/ -< home level 0 www.mydomain/about-us <- level 1
    www.mydomain/about-us/history <- level 2.
    This also works beter if you ever add subdomains (you can bind subdomains to the root home nodes .e.g "DE" , "EN" "NL" etc etc.
    Dec 02, 2016 @ 15:44
    Steve Morgan
    Updated with the correct screen shot!
    Dec 02, 2016 @ 15:50
    André van der Plas
    Hi steve,
    Thanks for the support. Your comments are clear. I will give it a try. :-)
    My collegue is interested in the config setting. Do you know which config setting it is?
    greetings,
    André
    Dec 02, 2016 @ 16:46
    Steve Morgan
    <add key="umbracoHideTopLevelNodeFromPath" value="false" />
    Here be dragons though... :)
    Steve
