2016-12-09 10:42:06,110 [P42092/D4/T96] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred
System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.InvalidOperationException: This document already has a 'DocumentElement' node.
at System.Xml.XmlDocument.IsValidChildType(XmlNodeType type)
at System.Xml.XmlDocument.AppendChildForLoad(XmlNode newChild, XmlDocument doc)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at umbraco.cms.businesslogic.packager.data.Reload(String dataSource)
at umbraco.cms.businesslogic.packager.data.GetFromId(Int32 Id, String dataSource, Boolean reload)
at umbraco.cms.businesslogic.packager.data.Package(Int32 id, String datasource)
at umbraco.cms.businesslogic.packager.InstalledPackage.GetById(Int32 id)
at umbraco.presentation.developer.packages.installedPackage.PageLoad(Object sender, EventArgs e)
at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at umbraco.BasePages.BasePage.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.umbracodeveloperpackagesinstalledpackage_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
2016-12-09 10:42:22,935 [P42092/D4/T131] INFO umbraco.BusinessLogic.Log - Log scrubbed. Removed all items older than 2016-12-08 10:42:22
/App_Data/ is shared, which from my interpretation of the documentation, is ok, because the log files are configured to be created with the machine name in the file name.
You're right. I'd forgotten the machine names had been added to the path. There is a configuration file in app_data that stores what packages you've installed. It's worth looking at that to see if there is anything wrong with it.
David,
Thank you for that suggestion !! The config file XML had a double entry.
When I removed the duplicate entry, it seems that the Umbraco part is working correctly. The plugin is still having problems, but I think now the symptoms are indicating that the problems are occurring with the plugin specific part of the code, which I will work on next. I will ask for help, if necessary, on the plugin git hub.
Plugin Installation problems on Web Farm
Using version 7.4.3
I have successfully installed a plugin to a standalone 7.4.3 version. The exact same plugin does not install to my web farm Umbraco 7.4.3.
When installing the plugin to the web farm version, the install step where it redirects hangs.
Later, when trying to look at the installed package, it gives this error:
Any tips on understanding this better appreciated -- Thanks, Bill
Looking at the Application Log --
2016-12-09 10:42:06,110 [P42092/D4/T96] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.InvalidOperationException: This document already has a 'DocumentElement' node. at System.Xml.XmlDocument.IsValidChildType(XmlNodeType type) at System.Xml.XmlDocument.AppendChildForLoad(XmlNode newChild, XmlDocument doc) at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) at System.Xml.XmlDocument.Load(XmlReader reader) at System.Xml.XmlDocument.Load(String filename) at umbraco.cms.businesslogic.packager.data.Reload(String dataSource) at umbraco.cms.businesslogic.packager.data.GetFromId(Int32 Id, String dataSource, Boolean reload) at umbraco.cms.businesslogic.packager.data.Package(Int32 id, String datasource) at umbraco.cms.businesslogic.packager.InstalledPackage.GetById(Int32 id) at umbraco.presentation.developer.packages.installedPackage.PageLoad(Object sender, EventArgs e) at System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) at System.Web.UI.Control.OnLoad(EventArgs e) at umbraco.BasePages.BasePage.OnLoad(EventArgs e) at System.Web.UI.Control.LoadRecursive() at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.HandleError(Exception e) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest() at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) at System.Web.UI.Page.ProcessRequest(HttpContext context) at ASP.umbracodeveloperpackagesinstalledpackage_aspx.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) 2016-12-09 10:42:22,935 [P42092/D4/T131] INFO umbraco.BusinessLogic.Log - Log scrubbed. Removed all items older than 2016-12-08 10:42:22
Does each server have it's own copy of /App_Data/, and file write permissions to it?
David, Thank you for that suggestion !! The config file XML had a double entry. When I removed the duplicate entry, it seems that the Umbraco part is working correctly. The plugin is still having problems, but I think now the symptoms are indicating that the problems are occurring with the plugin specific part of the code, which I will work on next. I will ask for help, if necessary, on the plugin git hub.
Thanks again!! -- Bill
