  • Chris Clancy 65 posts 134 karma points
    Dec 08, 2016 @ 14:55
    Chris Clancy
    Handling 404s for Multi Site Umbraco 7.5.2
    I originally set my 404 page up in the umbracoSettings.config file and it worked fine ....until I realised that the two other sites in this instance were using the same 404 page as site no.1, which is not going to work.
    I have gone with standard 404 handling, using an Xpath statement to point to my custom 404 page.
    <errors>
      <error404>//errorPage[@nodeName='404']</error404>
    </errors>
    I have looked into uComponents package but that doesn't seem to be supported for version 7 Umbraco, so is there another way of handling multi site 404's?
    Also, the sites in question are running as an App on Azure, so it means no standard IIS 404 handling.
    Chris
  • Jonathan Richards 288 posts 1742 karma points MVP
    Dec 08, 2016 @ 15:31
    Dec 08, 2016 @ 15:57
    Chris Clancy
    Thanks Jonathan, I will investigate.
    Dec 08, 2016 @ 16:52
    Alex Skrypnyk
    Hi Chris,
    Did you try to use this package - https://our.umbraco.org/projects/backoffice-extensions/umbraco-page-not-found-manager/ ?
    It's really helpful.
    Alex
    Dec 13, 2016 @ 10:53
    Chris Clancy
    Hi Alex,
    Yes I did try that package and it works very well. The only issue I have is to ensure that the config file is excluded from the repo or it will keep on being over written.
    thanks
    Chris
