  • Niall Kelly 5 posts 85 karma points
    Dec 08, 2016 @ 15:21
    Niall Kelly
    Trouble installing Umbraco with nuget
    I am new to Umbraco and I am having some difficulty installing Umbraco via nuget. When I run the project to start setting up Umbraco I get the following error:
    Any ideas?
    Dec 08, 2016 @ 16:25
    Alex Skrypnyk
    Hi Niall,
    Did you install Umbraco successfully?
    Did you have some errors during installation?
    Can you check access to folders in your solution? It should be like there - https://our.umbraco.org/Documentation/Getting-Started/Setup/Install/permissions
    Hope it will help you.
    Alex
    Dec 08, 2016 @ 16:56
    Niall Kelly
    Hi Alex,
    Thanks for the reply. Whenever I enter my user details and click on customize, the error ExamineManager.Cs not found pops up and I cant complete the installation.
    I am looking to install the fanoe starter website with SQL CE database. Everything was working fine last week when I installed umbraco through nuget on a separate project. So a bit confused as to why I cant get it working now.
    Dec 08, 2016 @ 16:57
    Alex Skrypnyk
    What version of Umbraco are you using?
    Since last week 2 versions of Umbraco was released, I think you have to try to install previous version 7.5.4 I think with fanoe.
    Dec 08, 2016 @ 17:08
    Niall Kelly
    I thought that might be an issue. I am on 7.5.6. Will try and install previous version 7.5.4. Thanks
    Dec 08, 2016 @ 17:30
    Alex Skrypnyk
    Hope it will help.
    Have a nice evening!
    Alex
    Dec 08, 2016 @ 18:31
    Niall Kelly
    That worked.
    Niall
