  • Graham Thomson 56 posts 136 karma points
    Dec 09, 2016 @ 16:58
    Graham Thomson
    Developer - Form question - Surface controller
    I am following tutorials in Umbraco.TV.
    In the Developer - Surface Controller - Creating the model video
    At 35 secs in the tutor says in Visual Studio to go to the list on the right panel and right click on the Model folder....
    I cannot see a folder called Model - I have others like Media, obj,scripts, Views...... but no model.
    I am in Visual Studio 2015 Community edition and the video is using a previous version.
    Anybody got any ideas to help me?
    Thanks Graham
  • Marc Goodson 2157 posts 14434 karma points MVP 9x c-trib
    Dec 09, 2016 @ 21:10
    Marc Goodson
    Hi Graham
    You can just right click and create the folder called 'Models'
    Essentially when you create a new project in Visual Studio to use with Umbraco, you create an empty template, but you have the option to tick a box to add folders and core references,
    if you check the MVC box it will create the folders that the conventions of MVC suggest you use, eg a folder for: Models Views Controllers
    but it is completely ok if you are up and running just to create these folders manually...
  • John Bergman 483 posts 1132 karma points
    Dec 10, 2016 @ 00:32
    John Bergman
    If you are inside an Umbraco project, the models folder is not included in the project be default, you would need to "show all files" in the toolbar about the solution in the solution explorer to see the models folder.
  • David Peck 690 posts 1896 karma points c-trib
    Dec 10, 2016 @ 07:41
    David Peck
    Just to say, the Modal folder is a convention. Call it 'Captain Fancy Pant's Snazy Objects' if that is what floats your boat.
    Dec 13, 2016 @ 19:56
    Graham Thomson
    Many thanks all for the replies above!
