  • carlu 42 posts 131 karma points
    Dec 27, 2016 @ 11:52
    carlu
    Window Server 2008r2 and languge issue
    Hi all,I m using language switching in site,it does work well in local window 10 but when i upload that project at staging window server 2008r2 enterprise ,it doesnt work.Could u give me some suggesstion why this is happing in server.?
  • Arjan Woldring 124 posts 231 karma points
    Dec 28, 2016 @ 09:23
    Arjan Woldring
    Hi Carlu,
    You have to give more information on your issue. Is there an error? Are you deploying from visual studio? Which .Net Framework are you targeting?
    Dec 28, 2016 @ 11:38
    carlu
    Error
    Culture is not supported. Parameter name: name my-MM is an invalid culture identifier.
    EXCEPTION DETAILS
    System.Globalization.CultureNotFoundException: Culture is not supported. Parameter name: name my-MM is an invalid culture identifier.
    I am using .net framework 4.5 Thank You
    Dec 28, 2016 @ 11:54
    Arjan Woldring
    It might be the case that you haven't installed .Net Framework language pack on the server for the right framework.
    There are different language packs available. For example 4.5.1 Download Languagepack 4.5.1 or 4.5.2 Download Languageoack 4.5.2
    Dec 28, 2016 @ 11:56
    carlu
    Thank you Arjan Woldring.I will try.
    Dec 28, 2016 @ 12:53
    carlu
    Hi Arjan,I would like to know,how to check which .net framework language pack is installed in my window 10 64 bit?Thank You.
    Dec 28, 2016 @ 13:20
    Arjan Woldring
    Well you could see it under Add/Remove programs. On my system the language pack is part of ".Net 4.5.X Multi Targeting pack".
    But before that, what kind of culture is my-MM? Is that Myanmar or something? And is that even supported in c#?
    Dec 29, 2016 @ 02:20
    carlu
    It is Myanmar Arjan.I dont know well Is Myanmar language supported or not ,but in local window10 ,i already installed some myanmar fonts it works well .Thank you
    Jan 02, 2017 @ 11:18
    carlu
    HI Arjan,I cant find download link for .net framework 4.5 language pack for window server 2008 r2 enterprise.Could you help me please?
