  • Bilal Haidar 144 posts 410 karma points
    Dec 27, 2016 @ 19:47
    Bilal Haidar
    Configure Grid with 2 layouts: Container and Container Fluid
    Is it possible to give the editor the option to choose between using the:
    1. Bootstrap 3 Container
    2. Bootstrap 3 Container Fluid
    In other words, can I have 2 different layouts on the same grid configuration such that one uses normal Container and the other uses Container Fluid (Full Width)?
    Thanks /Bilal
  • Søren Kottal 713 posts 4571 karma points MVP 6x c-trib
    Dec 27, 2016 @ 20:16
    Søren Kottal
    Yes, you can build your grid rendering any way you want.
    Dig into the view in /views/partials/grid/bootstrap3.cshtml to see how it's built.
    Dec 27, 2016 @ 20:31
    Bilal Haidar
    Thanks. But will I be able to allow editor to choose whether to use this or that?
    As you know its already available in Bootstrap 3, but from what I saw, in the Template, you just ask the Grid to render using either Container or Container Fluid. So, how can this parametrized so that Editors can choose this or that way of rendering.
    Thanks /Bilal
  • Anthony Powell 13 posts 47 karma points
    Mar 23, 2021 @ 02:47
    Anthony Powell
    The answer is yes.
    You'll see in the code that the grid editor is looping through the rows.
    ~/Views/Partials/Grid/*.cshtml
    If you query the row.name. You'll notice it is the alias you used in the grid editor settings in the back office. Use that name to determine in the grid rendering whether to use container or container-fluid.
    Modify the renderRow helper to something like...
    @helper renderRow(dynamic row, bool singleColumn, bool IsFluid)
        <div @RenderElementAttributes(row)>
            @if (singleColumn)
            if (IsFluid)
                @:<div class="container-fluid">
            else
                @:<div class="container">
           @if (singleColumn)
               @:</div>
    Then when looping through the rows do something like this...
    <div class="grid-section">
       <div class="[email protected] column">
            @foreach (var row in s.rows)
                   @renderRow(row, false, row.name == "yourAlias")
    I know this is an old post. But I hate leaving things kinda unanswered.
  • hypnos97 2 posts 73 karma points
    Mar 23, 2021 @ 08:46
    hypnos97
    Tiết lộ kinh nghiệm đánh đề đầu đuôi miền trung ăn chắc nhất
    Cùng đọc bài viết dưới đây với chúng tôi để nắm được một số phương pháp soi cầu đầu đuôi miền trung hiệu quả và ăn chắc nhất hiện nay.
    Cách đánh đề đầu đuôi miền trung theo lô anh em
    Thực hiện cách này vô cùng đơn giản nhưng độ chính xác khá cao nên được các lô thủ ưa chuộng và lựa chọn đánh nhiều hiện nay.
    Với phương pháp soi cầu đề đầu đuôi miền trung theo cách này, đầu tiên người chơi  XSMT ◀◀◀ CLICK cần theo dõi bảng kết quả về kỳ quay thưởng trước đó của đài bạn muốn tham gia dự thưởng là các con số nào.
    Nếu bạn thấy kết quả lô về xuất hiện dãy số AB, AB + 1, AB + 3 mà không thấy về cầu AB + 2 vậy bạn chỉ cần lấy chính cầu này đánh cho kỳ quay thưởng tiếp theo XSMT của đài đó, tỷ lệ trúng tương đối cao và hiệu quả.
    Tính số đầu đuôi miền trung theo giải 8
    Đây cũng được xem là một trong số những cách soi cầu đầu đuôi miền trung hiệu quả và ăn chắc hiện nay mà nhiều lô thủ ưa chuộng.
    Cụ thể, thực hiện cách đánh này đầu tiên người chơi  Xổ số miền Trung hôm nay ◀◀◀ BẤM XEM cần theo dõi bảng kết quả mở thưởng về ngày hôm trước của đài bạn muốn tham gia dự thưởng dãy số giải 8 là con số nào. Sau đó, bạn chỉ cần lấy chính số lô đã về trong dãy số giải này làm cầu đánh kỳ quay thưởng KQXSMT tiếp theo vô cùng hiệu quả và chắc ăn.
    Ví dụ giải 8 về kỳ quay thưởng trước đó về là 27 vậy bạn chỉ cần lấy chính cầu 27 – 72 đánh kỳ quay thưởng tiếp theo.
    Soi cầu đầu đuôi MT theo giải 7
    Với phương pháp soi cầu đề đầu đuôi miền trung này, đầu tiên người chơi  Ket qua xo so mien trung ◀◀◀ TẠI ĐÂY cũng cần theo dõi bảng kết quả mở thưởng về trước đó của đài bạn muốn tham gia dự thưởng là các con số nào.
    Nếu bạn thấy số đầu tiên và số cuối cùng về trong dãy số giải này trùng nhau vậy bạn chỉ cần lấy chính các chạm của số đó làm cầu đánh những kỳ quay thưởng tiếp theo vô cùng hiệu quả và ăn chắc cao.
    Tuy nhiên khi thực hiện phương pháp này người chơi cần chú ý đến bảng thống kê miền trung, tránh trường hợp chọn nhầm các cầu lô gan như vậy đánh vừa không hiệu quả mà lại tốn tiền vốn ban đầu.
    Trên đây là tất cả những chia sẻ của chúng tôi về cách soi cầu đề đầu đuôi miền trung hiệu quả hiện nay. Hy vọng có thể giúp ích cho người chơi trong quá trình chọn cầu đẹp đánh đề đầu đuôi MT ngày sau chuẩn nhất, chúc các bạn may mắn!
