Don't know then, I can tell you I did have this problem with uskyslider installed (just in case anyone else runs into it); there was a discussion elsewhere about how to fix that specific issue.
We found out the the images there where affected buy this behavior, was registered as objects in the "cmsPropertyData" table (column dataNtext), with data like this:
Images not showing in media archive
Most of the images in our media archive is not showing in the media archive. It shows an url like this:
{src: '/media/1030/mypicture.jpg'crops: []}
It is like there are som cropping data, but we are not activily using cropping.
What can be the problem?
Thanks very much in advance
What other packages do you have installed?
Hi John
Thanks very much for your reply!
There are not installed any packages.
{src: '/media/1013/o9zjp30.jpg', crops: []}
Any idear on how it can happen?
