  • Nicholas Westby 2054 posts 7104 karma points c-trib
    Jan 04, 2017 @ 19:00
    Nicholas Westby
    "Culture is Not Supported" Error on Dictionary in Settings Section
    I created some languages in Umbraco, including "English (Austria)", as shown here:
    Languages
    That works fine on my local (Windows 10). However, when I deploy to dev (Windows Server 2012), I get this error when I click on "Dictionary" (in the Settings section):
    For the search engines, here's the text version of that image:
    Culture is not supported.
    Parameter name: name
    en-AT is an invalid culture identifier.
    Exception Details: System.Globalization.CultureNotFoundException: Culture is not supported.
    Source Error:
    Stack Trace:
    [CultureNotFoundException: Culture is not supported.
    en-AT is an invalid culture identifier.]
       System.Globalization.CultureInfo.GetCultureInfo(String name) +13714447
       umbraco.presentation.settings.DictionaryItemList.Page_Load(Object sender, EventArgs e) +89
       System.Web.UI.Control.OnLoad(EventArgs e) +109
       umbraco.BasePages.BasePage.OnLoad(EventArgs e) +38
       System.Web.UI.Control.LoadRecursive() +68
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4498
    Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.6.1087.0
    My guess is that different versions of Windows handle cultures differently. I came across this thread that links to some other threads: https://our.umbraco.org/forum/developers/extending-umbraco/71148-create-new-language-culture
    Seems like I need to register the cultures. Is there something I'm missing, or is registering the cultures using some custom C# code the standard way of handling this?
    Umbraco 7.5.6.
    Jan 04, 2017 @ 20:18
    Nicholas Westby
    I ended up creating a console application to register the cultures I need:
    // Namespaces.
    using System;
    using System.Globalization;
    using System.Linq;
    /// <summary>
    /// Console application that ensures the necessary cultures exist on the system.
    /// </summary>
    /// <remarks>
    /// This console application was necessary because some systems don't contain the necessary
    /// cultures, and this logic couldn't reside within the website as the creation of new
    /// cultures requires administrative privileges.
    /// </remarks>
    class Program
        #region Main
        /// <summary>
        /// Main entry point for the console application.
        /// </summary>
        static void Main(string[] args)
            EnsureCulturesExist();
        #endregion
        #region Private Methods
        /// <summary>
        /// Ensures all the necessary cultures exist (e.g., "en-AT" doesn't exist on some computers).
        /// </summary>
        /// <remarks>
        /// Some of this code comes from https://msdn.microsoft.com/en-us/library/system.globalization.cultureandregioninfobuilder.aspx
        /// and http://stackoverflow.com/a/16476935/2052963.
        /// </remarks>
        private static void EnsureCulturesExist()
            // Variables.
            var allCultures = CultureInfo.GetCultures(CultureTypes.AllCultures);
            var ignoreCase = StringComparison.InvariantCultureIgnoreCase;
            // Reusable cultures/regions.
            var english = CultureInfo.CreateSpecificCulture("en-US");
            var austria = new RegionInfo("AT");
            var germany = new RegionInfo("DE");
            var sweden = new RegionInfo("SE");
            var switzerland = new RegionInfo("CH");
            // Register English (Austria) / "en-AT".
            var englishAustriaExists = allCultures.Any(x => "en-AT".Equals(x.Name, ignoreCase));
            if (!englishAustriaExists)
                var englishAustria = new CultureAndRegionInfoBuilder("en-AT", CultureAndRegionModifiers.None);
                englishAustria.LoadDataFromCultureInfo(english);
                englishAustria.LoadDataFromRegionInfo(austria);
                englishAustria.CultureEnglishName = "English (Austria)";
                englishAustria.CultureNativeName = "English (Austria)";
                TryRegisterCulture(englishAustria);
            // Register English (Germany) / "en-DE".
            var englishGermanyExists = allCultures.Any(x => "en-DE".Equals(x.Name, ignoreCase));
            if (!englishGermanyExists)
                var englishGermany = new CultureAndRegionInfoBuilder("en-DE", CultureAndRegionModifiers.None);
                englishGermany.LoadDataFromCultureInfo(english);
                englishGermany.LoadDataFromRegionInfo(germany);
                englishGermany.CultureEnglishName = "English (Germany)";
                englishGermany.CultureNativeName = "English (Germany)";
                TryRegisterCulture(englishGermany);
            // Register English (Sweden) / "en-SE".
            var englishSwedenExists = allCultures.Any(x => "en-SE".Equals(x.Name, ignoreCase));
            if (!englishSwedenExists)
                var englishSweden = new CultureAndRegionInfoBuilder("en-SE", CultureAndRegionModifiers.None);
                englishSweden.LoadDataFromCultureInfo(english);
                englishSweden.LoadDataFromRegionInfo(sweden);
                englishSweden.CultureEnglishName = "English (Sweden)";
                englishSweden.CultureNativeName = "English (Sweden)";
                TryRegisterCulture(englishSweden);
            // Register English (Switzerland) / "en-CH".
            var englishSwitzerlandExists = allCultures.Any(x => "en-CH".Equals(x.Name, ignoreCase));
            if (!englishSwitzerlandExists)
                var englishSwitzerland = new CultureAndRegionInfoBuilder("en-CH", CultureAndRegionModifiers.None);
                englishSwitzerland.LoadDataFromCultureInfo(english);
                englishSwitzerland.LoadDataFromRegionInfo(switzerland);
                englishSwitzerland.CultureEnglishName = "English (Switzerland)";
                englishSwitzerland.CultureNativeName = "English (Switzerland)";
                TryRegisterCulture(englishSwitzerland);
        /// <summary>
        /// Attempts to register the specified culture, swallowing any errors that may occur.
        /// </summary>
        /// <param name="culture">
        /// The culture to register.
        /// </param>
        private static void TryRegisterCulture(CultureAndRegionInfoBuilder culture)
            try
                culture.Register();
            catch
        #endregion
    Couldn't build it as part of the website, as it needs to be run as an administrator to change some system files.
