  • Jorge 37 posts 119 karma points
    Jan 05, 2017 @ 17:06
    Jorge
    Property label dictionary not working
    Here is my document type property names, prefixed with # http://i.imgur.com/NVChc8g.png
    While this is my dictionary http://i.imgur.com/xHhAO0E.png
    And here is my content still not updated http://i.imgur.com/4OPTw1m.png
    I cleared cache, restart all but still dictionary not working, I am expecting the "Site" as "site xxx" but did not work.
    Please advise
  • Micha Somers 134 posts 597 karma points
    Mar 24, 2017 @ 15:42
    Micha Somers
    A bit late, so hopefully you already found a solution ...
    For those who are experiencing the same problem:
    The default user language is set to English (UK), in which case you won't see English US translated labels.
    So, check if the language setting for your own User Profile matches the one in your dictionary. In Jorge's example, the language should be set to: English (United States)
    In case the translated labels are still not visible after having changed your language setting: logout and login again in order to see the translated labels.
