Hey i have a problem one os my nye sits has a admin user that i can't get in to and i ned to get it to it.
so i like to make a clean instal more but i only have one DB so i ned to chance the DB prefix how do i do it..
and i have look at the reset parsword tread ware just to set it to clear but it will not work i get a error of som whit asp. member. so can't chance it that way..
Also:
If you have access via FTP to the site, you can change the SQL connection string in the web.config at the root of umbraco. Search for connection string.
<connectionStrings>
<remove name="umbracoDbDSN" />
<add name="umbracoDbDSN" connectionString="Data Source=CONNECTIONSTRING HERE" providerName="System.Data.SqlClient" />
<!-- Important: If you're upgrading Umbraco, do not clear the connection string / provider name during your web.config merge. -->
</connectionStrings>
But to make a clean install you just reset the database to 0 and start again.
Login problem
wath do i do...
I have used Umbraco Admin Reset, and it works perfectly. You could try this : https://our.umbraco.org/projects/developer-tools/umbraco-admin-reset/ Username will be reset to Admin and password to Admin1234!
Also: If you have access via FTP to the site, you can change the SQL connection string in the web.config at the root of umbraco. Search for connection string.
Hi Michael,
If it´s a Umbraco 7 website, then you can try to use this: https://our.umbraco.org/projects/developer-tools/umbraco-admin-reset/
Hope this helps,
/Dennis
